Maybe a makeup problem??
TrishTrish Posts: 2,625
edited March 2013 in New Users
I injected the angel face (head) on the gen char and wanted to show her from the side view and heres what I have, how do I correct I guess would be called the makeup... difference in color??........Thanks in advance Trish
398 x 308 - 109K
Post edited by Trish on
  • Scott LivingstonScott Livingston Posts: 4,344
    Some textures come with options for two or more shaders (for example, DAZ Studio default shader and Elite Human Surface Shader) or options for DAZ Studio and for Poser. My guess is that you've applied one to the body, and then a different one to the face. The makeup you want should exist in another version that's compatible with the body texture you've applied.
  • Richard HaseltineRichard Haseltine Posts: 102,682
    You had applied a full mat before applying the makeup mat?
  • TrishTrish Posts: 2,625
    edited March 2013
    This time I put her on v4.2 and used angel body inj. and face inj. and when I added the angel makeup this is what I have now ...I don't think I understand what you are trying to tell me P.S. you can also see her hands aren't the right color either...I don't know what I'm doing
    711 x 702 - 612K
    Can you provide a link to the product you're using (the Angel character or texture set)?
    Here she is she came from a bundle
    264 x 371 - 172K
    The INJ poses probably apply morphs but not materials, there should be an all-over mat pose that you need to apply before using any of the makeup poses.
    any ideas you have would be great richard so far I have tried all of these buttons...Where would I look??
    1396 x 719 - 958K
    You need to apply the first pose, the one that shows in the 2nd box along on your top line, before you apply any of the various makeup poses.
    edited March 2013
    Chohole; here she is with the second button from the left with out any makeup......I knew better than to start messing with studio I should just stick to Bryce....This is over my head
    428 x 583 - 249K
  • JaderailJaderail Posts: 0
    Do you have the Full Figure selected? It looks to me as if you have some Surfaces not Selected in the Surfaces Tab. For pre-made Mat files you do not need to select the Surface in the Surfaces Tab. Select the Full figure in the Scene tab then Check to be sure the Full Figures Surfaces are selected in the Surfaces tab. Then Apply any of the Mats. They will AUTO load into the proper places.
    edited March 2013
    Someone correct me if I'm wrong (I don't own that character) but the pz2 files from your screenshot are Poser-format material presets. According to the product page, the character comes with DAZ Studio material presets too (dsb files). If a readme file was included in the download, it should tell you where to find the correct textures for DAZ Studio (the online readme is here, but it's incomplete: http://docs.daz3d.com/doku.php/public/read_me/index/10153/start)
    Sometimes the poser files will have a little scroll icon, meaning that if you load them in DAZ Studio, the correct DAZ-format settings will automatically apply, but from your screenshot that doesn't seem to be the case here.
    Post edited by Scott Livingston on
    Scott I found 2 read me's I am guessing because it was in a bundle here they are...I am so confused with this thing.....
    1396 x 538 - 20K
    1520 x 562 - 42K
    Here are the pics with the files the figure turns a dark color when I apply the tatoos as seen in the last pic
    350 x 455 - 43K
    350 x 455 - 42K
    Is there anyway to ask 4blue eyes he or she would know they made her???
    edited March 2013
    Yes, you could send the artist (looks like the character was made by maelwenn, and 4blueyes was the clothing creator) a PM if you can't get it working. As far as I know, usually PAs are happy to provide support for their products.
    Based on the readme, I would suggest looking here in the Content Library: DAZ Studio Formats>People>Victoria 4>Character>Angel V4. Like Jaderail said, make sure you have the entire figure selected, and not just certain surfaces (in the Surfaces tab).
  • BWSmanBWSman Posts: 0
    edited March 2013
    The main issue is that the diffuse strength for the various parts of the body are different. For example; the Skin Face diffuse strength is set to 90% while the Skin Head is set to 100%. Also the ambient strength goes from 2% to 100% (although with the ambient colour being so dark that makes less of a difference. Just adjust all the surfaces to read 100% in the diffuse strength & you should be good to go.
    Edit to add: there are DS specific material settings. In your content library; go to:
    DAZ Studio Formats>Studio>People>Victoria 4>Character>AngelV4
    to and click on ++AngelV4 Tex
    438 x 865 - 171K
    438 x 868 - 172K
    Post edited by BWSman on
  • BejaymacBejaymac Posts: 1,897
    I don't have this but I've been asking around, and if my friend is correct then you should have four installers for this, three add the morphs, textures and Poser materials, which will install into the Runtime structure, while the fourth has the DS native format presets, which if installed correctly should be under "People > Victoria 4 > Characters" in the DS native directory.
    edited March 2013
    Thanks everyone for trying to help me this is getting to be really hard....
    BWSman; I did what you said and everything was fine the entire body did become the same color, until i put this outfit on and the darkness came back
    1902 x 935 - 816K
    My Friend that's is what is Called a Second Skin. It's not really a Out fit it's just another texture. All that stuff in that folder is textures you just fix it like you did the other ones you used.
  • maelwennmaelwenn Posts: 36
    Hi bullit35744!
    Are you sure you installed the DS material presets in Daz Studio from the separate installer? If you did you should see this when you open the folder where the MATs have been installed.
    Isabelle
    1091 x 664 - 298K
    Then everything should load fine like the image below :)
    1185 x 969 - 262K
    I really appreciate everyones help ...I went back to my downloads and re-did everything and she works fine now ...Thank you maelwenn she is a beautiful character!!!!!
    You are very welcome and thank you for your kind words! :)
    Isabelle
  • NextOSNextOS Posts: 10
    edited May 2013
    Hi Maelwenn,
    My name is Guile Lindroth, CEO of Guile 3D Studio, the builders of the software "Virtual Assistant Denise" at www.guile3d.com
    I'd like very much to talk to you about one of our projects, but I'm not being able to reach you.
    Is it possible for you to contact me at guile3d "at" guile3d.com
    Thank You!
    Post edited by NextOS on
