Saving a Prop without moving
Hi,
I would like to save a face mask for G3F but I do not know how to save it.
I created the mask in Hexagon and sent it to DAZ. And now I have my problem. I want to save it as a prop attached to G3F but it should not move with the jaw or other expressions.
I did following; Transfair utility - content typ Prop/Face; Prop/Head; Follower/Attachement; Follower/Weardrobe
Before G8F came out I saved the prop, load it and attached it by hand to the figur, so the Mask would move with the head.
Now I want the mask on the G8F but it did not fit to G8F. So I thought I use the Autofit-function. But the function did not work. It only works when the mask is transfaired to G3F and saved. But than the mask move with the face.
What am I doing wrong? What can I do to fix it?
Thank you for your help
Manfred
  • Richard HaseltineRichard Haseltine Posts: 102,890
    AutoFit is for fitted figures, not parented props. You may need to adjust the mask in Hexagon if you can't simply move it to fit in DS
  • ExperimenterExperimenter Posts: 162
    Thank you. Is there a saving option to save the mask (prop) attached to the G3F?
    I load the prop in the scene and I then I attach the prop to the head by hand. Is there an option to skip this hand attachment by the saving?
    Parent it, then File>Save As>Wearables preset.
    Okay, thank you.
