Problems when changing posing
BeemBeem Posts: 95
edited August 2017 in New Users
When i change posing for a figure i get problems,  for ex the hat does not  follow the figure - se image below.
Sometimes i have the same problem with hair. The clothes always follow the new pose.
618 x 800 - 111K
Post edited by Beem on
  • Sfariah DSfariah D Posts: 26,567
    Is this in Daz studio? How have you parrented the prop aka the hat to the figure's head?
  • BeemBeem Posts: 95
    edited August 2017
    Yes Daz Studio.
    I did as i did with the clothes.
    I pick the head -  rightclick and drag the UV - fit to genesis 3 female
    Then material rightclick and drag - fit to g3f  sunhat UV
    Beem said:
    Yes Daz Studio.
    I am getting confused.  Can you show a screenshot of your Daz studio set up?
    Here comes a screenshot
    1911 x 1030 - 461K
  • TottallouTottallou Posts: 555
    I suspect that you did not have your G3 selected when you added the hat to the scene so it is not parented to the head of your model.
    I have this Wilpmap set & it follows poses as long as the hat is parented to the figure - The easiest way to fix it now is to delete the hat - Select G3 and load it again and it should work with any poses
    I will give it a try again. Thank you.
