Is there a way to change the default materials an item or character initially loads with?
MimicMollyMimicMolly Posts: 2,212
For example, I'd like to load an item to the scene that has Iray materials by default, but I want to use the 3Delight materials instead without having to always switch/add the appropriate shaders/materials every time I use it. Is it possible to change/save these settings as the new default?
If it's possible, it may convince me to buy more items or pick up some new freebies, since I also use the conversion script mentioned in this forum postwink
If it is different the opposite way (3Delight to Iray) I'd like to know too for future references or whenever I upgrade my PC.
  • Just save a new Character preset with the desired materials, or a Scene subset (both in the File>Save as menu).
  • MimicMollyMimicMolly Posts: 2,212
    Reading into it, the character preset is what I was looking for. Thank you. :)
