DS Bridge problem
![04Janine87](https://secure.gravatar.com/avatar/ddb438be76af23276ec1be581e742bd9?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fddb438be76af23276ec1be581e742bd9_100.png)
I am new to Hexagon, so I hope that someone can help me with my problem.
In some other thread someone posted: "Changing geometry in Hexagon will make it so that a morph cannot be created. The object can still be sent to Daz Studio but it will be imported as a prop. Geometry is changed when faces/edges/vertices are added to or removed from the sent over geometry."
I understood that I cannot remove or add vertices but can pull them to change the shape of a clothing item for example? But if I do that and send the clothing item to daz the changes won't show. Am I doing something wrong?
Quick question, when you send it back to DAZ Studio a box opens first asking you to name the morph etc - Are you getting this ?
If you filled in the box, you should have a "dial" in DS's Properties (under the info you put in the box above).
