Luminance Units
I've lost the 'Luminance Units' option, can someone please point me in the right direction?
Does it only appear on certain types of lights? I would have thought it would be with all the other light-related options.
Thanks
  • Make sure you have the iray engine selected under render options. You need that in order for the iray options to show up under the lighting parameters.
  • Is your render engine set to Iray? Is the Photometric button set to On for the light?
  • supernoobsupernoob Posts: 154
    Render engine is set to iray, photometric is on.
    Where is the luminance unit option supposed to appear?
  • RobinsonRobinson Posts: 751
    edited August 2017
    It's Luminous Flux (Lumen), usually on Light -> Photometrics page of Parameters for the light.  If you hid it by mistake, click the 4 bar menu on the parameters page and "Show Hidden Properties".  You can then unhide it.
    Edit, duh.  You want Luminance Units, not Flux.
    Post edited by Robinson on
  • rames44rames44 Posts: 332
    On my system, at least, I only get lumens for spotlights. On mesh lights (i.e. objects that have been set to use an emissive shader) I get the units. I would have thought that the units would have been present on spotlights that are not "point" geometry. But then, I didn't design the program...
