Turning prop clothes in Old Edo by sugatak into actual clothes
hiyashi_yasurohiyashi_yasuro Posts: 32
Does anyone know how to convert the kimonos in the Old Edo set by sugatak into actual wearable clothes? The kimonos are props and I can't get my figures to wear them. I also don't know which generation of figures the clothes were made for. It doesn't fit Genesis or V4/A4.
    Which set is this in? Are you sure they are made for any Poser figure - they may just be props, especially if they are draped rather than being in the standard T pose.
  • hiyashi_yasurohiyashi_yasuro Posts: 32
    Old Edo Vol 3 is the one I'm talking about.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,206
    I do not have the set but suspect they are Poser dynamic cloth
    You could try using the transfer tool on them if so.
    Considering that they are indeed posed, I thinks the expectation is that you will adjust a figure to fit inside the clothing rather than vice-versa. I don't know which figure they were made around, however.
  • ytetsuytetsu Posts: 46
    They are made for posed figures as a prop.
    So, you can't change their pose.
    I couldn't find target figure name in the ReadMe.
    But according to pz files, they are Victoria 4 and Ryan.
    I checked one for v4, and it worked.
