Shape saving for V4?
Hi, I'm trying to save a V4 figure I spent some time morphing and tweaking and want to save the save to use on a new V4 vanillia model that I have injected bending morphs into - so to simplify, load a new V4 and merge pre-crafted shape. I have tried save as a shape preset but when I try to merge it onto vanilla Vicky it does nothing.
Thanks!
  • Richard HaseltineRichard Haseltine Posts: 99,473
    Were you using standard morphs or new morphs you had created by directly deforming the mesh, in DS or in a modelling application?
  • edited December 1969
    Morphs I bought, like glute and leg bend fixing morphs. Nothing I made, but morphs made specifically for Daz V4.
    edited March 2013
    No, that suggestion was bad - I just checked and it looks as if the V4 morphs all load set to Shapes so a Shaping Preset should work, unless the morphs you are using are not being set correctly for some reason - go to the Parameters pane, click Used, then click the little gear on the slider and select Parameter Settings from the menu - does it say Modifier/Shape for Type?
    No, it just says Modifier/Shape and in the used has EMPTY next to sliders.
    Maybe I'm loading the saved Duf file wrong. I've tried dragging the saved Duf file onto the figure and also loading via the Merge option.
    Try using the File>Save as>Deprecated>Pose preset, or Character preset (includes materials), and see if they work.
