Help With Morph Loader Pro
Hi guys,
I am having a bit of trouble with morph loader pro. I created a morph for V4 in Zbrush and exported it as an OBJ, but when I try to use morph loader pro to import the morph to a fresh V4 in Daz, nothing happens. The dialogue says "Created morph successfully" but nothing was actually added to the model. At first I thought it might be a scaling problem, (I think its supposed to be 1 unit = 1m?) but I tried all the other settings and still it does nothing?
Did the Morph add a new Dial in Parameters? If not you may need to pick a Channel not used by another morph.
hello, I also have this problem. load the obj with morph loader pro and tells me that everything was done successfully but nothing shows ...
