Please remember to put the question in the body of the post as well as in the title.
If it's a scene subset, not a full scene, try holding down opt/alt as you drag the file in from a content pane, releasing the mouse when the target icon on the floor shows the origin you want to load relative to.
Sorry about that. I meant a full scene merge though.
The only way I found it to be fast to move a merged object is to have a new camera and parent that object to it and manually add the xyz values from the camera where I want it to be moved, but I was hoping there was a better solution than that.
I just checked, alt/opt-dragging does work to merge even if the file is a scene (which, by default, would repalce the current scene if double-clicked)
