Fixing bend of abdomen for G3F
When I bend the Pelvis in minus and the lower or/and upper abdomen in plus I get these results:
Is there a way to fix the stomach so it looks more smooth? The same thing happens for G8F btw. too.
1280 x 720 - 138K
  • SixDsSixDs Posts: 2,384
    edited September 2017
    Use the bends with the lower and upper abdomen selected judiciously. Here I have the upper set to 25 and the lower set to 20. That doesn't produce a noticeable fold. However, if you are looking for a more extreme bend to your character, use the above settings, then select each of the right and left thighs, and bend those (they are both set to about -40 here) to complete the operation, as shown in the render below. If you still do not like the slight fold, you could always apply a smoothing modifier to the figure and that should pretty much eliminate it. BTW, that is exactly how we bend - there's not that much flexibility in the spine.
    500 x 500 - 137K
    Post edited by SixDs on
  • Yes if you want an extreme lean over bend like that what you really have to do is bend the legs forward at the hips. Study your own movements for a while.
