"Cannot find a file for..." error
SertorialSertorial Posts: 962
edited March 2013 in New Users
I get this quite often.
I load a prop (in this case, a .PP2 file) and then I get an error saying
Cannot find a file for "Example.jpg"
To avoid seeing this message, make sure that the poser content directories are set up properly"
If I then click on "Locate" it points to the directory where the prop file is
My Library\Runtime|libraries\Props\Creator name\
It's trying to load a texture file, but can't find it, I assume.
but there ain't no texture in there. Instead, the relevant textures seem to have been unzipped to My Library\Runtime\textures\Creator name\
So, I reckon I'll copy the textures from there into the folder it appears to be looking in.
Still no joy!
How do I stop this happening? And why did they unzip to \textures if that's not where they're supposed to be?
Post edited by Sertorial on
  • fixmypcmikefixmypcmike Posts: 19,612
    Make sure that the folder containing the runtime folder is listed as a Poser-format content folder.
    It's putting you in that directory because it's not seeing it in the texture folder in a listed content folder.
  • SertorialSertorial Posts: 962
    um..how do I do that?
  • JaderailJaderail Posts: 0
    From the Paths listed I think the Issue might be a Folder name or a Full Folder in the texture path might be wrong in the PP2 file.
    yes, I wondered that. So I opened the .PP2 file with a text editor, but the only reference to the texture is just the filename without a path. I presume if no path is there, it will assume the file is in the same folder as the .PP2
    If this is a Free item from a Site I could take a look at it for you and maybe offer a fix. All I need is the name or a link if you have one.
    That is where they're supposed to be — don't move textures around like that, or you'll have exactly the same errors cropping up when whatever's causing your problems has been fixed.
    Incidentally, that issue of filename-only-no-path was very common with items (sadly, not all of them free ones) created several years ago, before DAZ|Studio had been released and all this stuff was only used in Poser. The correct way to specify file paths was not commonly known back then, but most of the time these messed-up items worked because Poser was a lot more forgiving of the glitches. The last couple of versions of DAZ|Studio in particular have been more fussy — if the paths aren't right, you get an error.
  • TotteTotte Posts: 14,088
    There are two common errors in older Poser content.
    One is with onlöy a filename given, and one that works on Windows (sometimes) but never on Mac OS X, that is when the paths starts like C:\Runtime.......
    Seen that in several commercial items both at DAZ and in other sites, I've reported most the ones I've seen, but sometimes you're in a creative mode and no time to find and track down bugs....
    Ok, point taken. But how do I fix it then?
    If you open the .pp2 in a text-editor and look for a line like this
    textureMap "badpath.jpg"
    or
    textureMap "\Runtime\badpath.jpg"
    And change it to
    textureMap ":Runtime:Textures:SomePA:Someproduct:somfile.jpg"
  • Richard HaseltineRichard Haseltine Posts: 102,701
    You have three options:
    One, use a text editor to correct the path in the pose file or preset
    Two, manually load the textures using the Locate button and save a new Materials preset (File>Save as>Materials preset)
    Three, assuming there's a full path in the existing preset, move the textures to where the file thinks they should be
    I generally use one, occasionally two.
    or
    And change it to
    Excellent! Worked a treat! Thank you :)
    edited April 2013
    Incidentally, are there other types of content file that this broad approach will work with? (not necessarily the same syntax, I realise, but a text file with a path in it that can be fixed)
    or
    And change it to
  • BWSmanBWSman Posts: 0
    or
    And change it to
    Character files (.cr2); hair files (.hr2) face files (.fc2) and pose files (.pz2) can all be edited in the same manner.
    or
    And change it to
    Great. Thanks for that.
