Mass export of OBJs
Philemo_CarraraPhilemo_Carrara Posts: 1,175
Hi to all,
I'm using Carrara to setup scenes and Octane to render them.
This workflow works very well for still images but is a pain for animation.
So, I was wondering if there was a way to easily export all the OBJs of an animation in one operation (plugin or sofware option I've missed despite reading the documentation and trying anything I could think of) ?
Thank you for your help
Philemo
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,464
    not familiar with octane at all but if it handles FBX that is the format to use for seperate objects with animation.
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    I'm afraid not, only OBJ :-(
    But there is an idea behind that.
    Maybe I could use a third party software that could export a sequence of OBJs from a FBX.
    I'll try first with FBX convertor, one never knows...
  • Arcane Von OblivionArcane Von Oblivion Posts: 149
    is octain able to import MDD files?
    Nope. It's either OBJ or OBJ, through I think it could be also OBJ.:-)
    There is also an export plugin for DAZ4D, but it brings other problems in the workflow.
    I must say I was hoping for an obscure plugin I haven't found, but I'm afraid I will have to forget that track :-(.
    As I realise some of you may not know Octane (and maybe to show off a little ;-) ), I've attached some of my renders, so that you may have a hint of what is possible using it for final rendering(for a 99€ render engine).
    It could be even better still, I'm just learning as I go.
    1024 x 512 - 791K
    940 x 350 - 460K
    1920 x 1440 - 2M
