Conforming Michael 5's genitals to his body
BrianG61
Hello,
I'm a long time user of Poser and a new user of Daz Studio 4.5. I'm trying to get Michael's stuff to fix to his body in Daz Studio, but have been completely unsuccessful. Can someone please provide clear instructions on how to accomplish this?
Thanks
Brian
All I do is select the figure and then Double click the toast (gens) they should autofit.
EDIT to ADD. You then need to SELECT the M4 again before you pose. If not only the Toast will pose because it defaults to selected on load.
Thank you very much! That did the trick.
User #1336, just in case you run into the problem again, but you already have the item loaded into the scene (let's use a shirt as an example). You can select the shirt in the scene tab or by right clicking on the shirt in the document window and choosing the shirt from the pop-up list. Then go to the parameters tab, click on "Misc" and there will be an option for choosing the character you want to fit the shirt to, very similar to Poser's "Fit To" option.
Thanks for the tip Slosh.
