Windows 8 & Carrara Beta = Mesh Issues?
None
Well it's not just the beta doing it as the stable does it too, is anyone else using Windows 8 and seeing an issue with the eyebrow mesh, seems to happen when you select any pose, it is like the mesh comes away from the face, as if V4 is wearing a mask.
I would post an image but I went back to Windows 7 to test it out and I am not getting the issue on here, I have the same programs installed as with Windows 8, so the only difference is the OS
So i am the only lucky one to be getting this?
Just tested this for you and I'm having no problems at all on Win 8 64bit using Carrara 8.5. I don't have 8.1 installed and I left it to the Content Install Manager to install my library.
hmmm - guess I am the lucky one then :(
You have my sympathies.
ManStan you seem to have the wrong end of the stick, the install manager works fine for me.
Hi Cool Art Dude :)
The "Eyebrow" mesh became an issue with V4 in most programs including DS , so it's not a Carrara, or Win8 issue.
The brow can be selected and made invisible in the instance list,. or (it should already have an alpha material to make it invisible) but some poses can change or effect the brow mat.
hope it helps :)
