questions about dystopia-destinations-hyperion-bar
bbaden6465bbaden6465 Posts: 0
ok it has a note that says
"extensive use of procedural texturing means this product requires Poser 5 or above. To use the product in DAZ|Studio or Poser 4 and below, a separate set of textures would be required."
just wondering if that applies to daz studio 4.5 pro (not sure if it worked around it or not)
and if the note does applie will i still be able to use it just miss out on some lights what exactly will i be losing
  • Richard HaseltineRichard Haseltine Posts: 99,473
    Yes, it still applies. DS does have procedural materials, via Shader Mixer, but it isn't possible to translate the Poser Material Room settings to DS Shader Mixer settings. I don't think anyone has made a set of textures or DS shaders for the set, so you would need to create your own - certainly possible, but a fairly hefty task I fear.
    Wasn't there a set of D|S materials made up for Hyperion? Yes, just checked and I have them — although I haven't reinstalled them on this computer since my last runtime rebuild. There were links (I think) in the old forums. Anyone remember where they were?
    Here http://forumarchive.daz3d.com/viewtopic.php?t=61843 , but it looks a if the links are dead.
