EcVh0 skin anomaly
in New Users
The line right near the chin, the face looks like she is wearing make-up that does not match the tone of her skin. The lighting and angle are not the cause as its in all my shots.
920 x 1180 - 600K
I see what you demonstrated.
I once had the same experience with a merchant ressource. I returned it. Seems as if those textures are worse compared to the ones of the standard actors.
But also translucency and transmission setting can have some influences.
Hey Vanishot!
i just had a look at your render, seems like you are using pale skin shader? Does it have the same problem with the normal shader?
it seems to be a problem with texture itself, the line isn't actually at the change of textures (so it's not the texture difference problem) I will have a try to see if I can remove the darker shade at the bottom part of the texture and will let you know how it goes :)
EcVh0
Thank you.
This is a render of V8 fresh out the box. If this is what you were meaning, than I am not noticing the same issue.
Also Im afraid I lost track of our personal message thread in case you sent something, I have not seen it/no messages in my inbox.
whatcha think?
