weight maps
Is there a way to get hold of the weightmap information attached to a vertice / mesh or bone?
I can get the node, the vertex, the Skeleton and the bone. I hear that boneBinding links the two together, but how do you get that information?
I suspect, looking at the DS3 scripting, that you need to get the joint modifier, in DS you'd get the DzPoserJointParam from there and then the weight maps from the joint param. However, that's all Poser-style rigging (Legacy rigging) so I'm not sure how it woudl need adapting, and the modifiers don't yey seem to haev documentation so you'd have to go into discovery mode (iterate over the object's members) and see what you coudl figure out.
There are quite a lot of SDK/scripting chnaegs in the Change Log ( http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#private_channel ) so bear in mind that this area may be subject to change
I have found out, searching a little bit in the weekend, some objects for the weight map manipulation (DS 4.10.0.123).
I managed to make FaceGroups and to set new Bones for 750 nodes in a few mins with a script (ok I needed 2 days searching and writing the script but it was better than re-arrange manually 750 nodes in the Figure Setup pane). Using the next objects I managed to add "General Map" to all the new bones at once!
I know that there is no documentation yet so the next list is retrieved throught the Scripting IDE console. I am not sure about the inheritance of each object as I hadn' t the time to check it.
-- [DzWeightMapHandler] [ It seems to inherit "DzBase" (not sure for any other parent object):
=== An easy way to retrieve it is throught DzSkeleton.getSkinBinding() method
"objectName",
"name",
"destroyed(QObject*)",
"destroyed()",
"deleteLater()",
"nameChanged(QString)",
"className()",
"makePersistent()",
"inherits(QString)",
"iskindof(QString)",
"getName()",
"numWeightGroupsChanged()",
"currentWeightGroupChanged()",
"currentWeightContextChanged()",
"numWeightMapsChanged()",
"possibleWeightMapsChanged()",
"currentWeightContext()",
"canEditWeights()",
"getNumWeightGroups()",
"getWeightGroup(int)",
"setCurrentWeightGroup(DzWeightGroup*)",
"currentWeightGroup()",
"buildViewContextMenu(QMenu*)",
"buildMenuPreWeightMapBrush(Dz3DViewport*,DzMenu*,QPoint)",
"buildMenuPostWeightMapBrush(Dz3DViewport*,DzMenu*,QPoint)",
"getNode()",
"getFigure()",
"getSkinBinding()",
"setCurrentContext(DzNodeWeightHandler::BindingMapType)",
"setSymmetricWeightAxis(int)",
"getSymmetricWeightMap(DzWeightMap*)",
"getSymmetricWeightAxis()",
"setFigureContextForType(DzNodeWeightHandler::BindingMapType)"
[DzSkinBinding()] [ It seems to inherit "DzElement" or DzProperty (not sure):
=== An easy way to retrieve it is throught DzWeightMapHandler.getSkinBinding() method
"objectName",
"name",
"elementID",
"assetUri",
"assetSource",
"assetId",
"assetAuthor",
"assetFileRevision",
"assetModifiedDate",
"destroyed()",
"deleteLater()",
"className()",
"makePersistent()",
"getName()",
"propertyAdded(DzProperty*)",
"propertyRemoved(DzProperty*)",
"propertyListChanged()",
"propertyListInTreeChanged()",
"propertyTreeChanged()",
"privatePropertyAdded(DzProperty*)",
"privatePropertyRemoved(DzProperty*)",
"privatePropertyListChanged()",
"privatePropertyListInTreeChanged()",
"privatePropertyTreeChanged()",
"labelChanged(QString)",
"parentChanged()",
"mergeElementSignal(const DzElement*,DzElementDuplicateContext*)",
"duplicateElementSignal(DzElement*,DzElementDuplicateContext*)",
"createElementCopySignal(DzElementDuplicateContext*)",
"setAttributes(const DzSettings*)",
"setName(QString)",
"setLabel(QString)",
"update()",
"clearAnimData(DzTimeRange)",
"clearAllAnimData()",
"addProperty(DzProperty*)",
"insertProperty(int,DzProperty*)",
"removeProperty(DzProperty*)",
"removeProperty(QString)",
"moveProperty(DzProperty*,DzElement*)",
"addPrivateProperty(DzProperty*)",
"insertPrivateProperty(int,DzProperty*)",
"removePrivateProperty(DzProperty*)",
"removePrivateProperty(QString)",
"movePrivateProperty(DzProperty*,DzElement*)",
"addDataItem(DzElementData*)",
"removeDataItem(DzElementData*)",
"deleteDataItem(DzElementData*)",
"copyFrom(const DzElement*)",
"setLoadScript(DzScript*)",
"beginEdit()",
"finishEdit()",
"cancelEdit()",
"shouldSortOnLoad()",
"getLabel()",
"getAttributes(DzSettings*)",
"getNumProperties()",
"getProperty(int)",
"getPropertyList()",
"isPropertyNameUnique(QString&,bool)",
"isPropertyNameUnique(QString&)",
"getUniquePropertyName(QString)",
"findProperty(QString)",
"findProperty(QString,bool)",
"findPropertyByLabel(QString)",
"findPropertyByLabel(QString,bool)",
"getPropertyGroups()",
"findMatchingProperty(DzProperty*)",
"getNumPrivateProperties()",
"getPrivateProperty(int)",
"getPrivatePropertyList()",
"isPrivatePropertyNameUnique(QString&,bool)",
"isPrivatePropertyNameUnique(QString&)",
"getUniquePrivatePropertyName(QString)",
"findPrivateProperty(QString)",
"findPrivateProperty(QString,bool)",
"findPrivatePropertyByLabel(QString)",
"findPrivatePropertyByLabel(QString,bool)",
"getPrivatePropertyGroups()",
"getNumDataItems()",
"getDataItem(int)",
"getDataItemList()",
"isDataItemNameUnique(QString&,bool)",
"isDataItemNameUnique(QString&)",
"getUniqueDataItemName(QString)",
"findDataItem(QString)",
"getLoadScript()",
"copyToClipboard(QStringList)",
"copyToClipboard()",
"getNumElementChildren()",
"getElementChild(int)",
"getElementParent()",
"inEdit()",
"moveDataItemToIndex(DzElementData*,int)",
"findDataItemIndex(DzElementData*)",
"duplicateMissingCustomData(DzElement*)",
"duplicateMissingProperties(DzElement*)",
"duplicateMissingPrivateProperties(DzElement*)",
"duplicateMissingCustomDataWithContext(DzElement*,DzElementDuplicateContext*)",
"duplicateMissingPropertiesWithContext(DzElement*,DzElementDuplicateContext*)",
"duplicateMissingPrivatePropertiesWithContext(DzElement*,DzElementDuplicateContext*)",
"doMergeElement(const DzElement*,DzElementDuplicateContext*)",
"doDuplicateElement(DzElementDuplicateContext*)",
"mergeElement(const DzElement*,DzElementDuplicateContext*)",
"duplicateElement(DzElement*,DzElementDuplicateContext*)",
"createElementCopy(DzElementDuplicateContext*)",
"currentValueChanged()",
"aboutToBeRemoved()",
"removed()",
"added()",
"remapForTopologyChange(DzShape*,const DzIndexChangeSet*)",
"remapForTopologyChangeSlot(DzShape*,const DzIndexChangeSet*)",
"boneBindingAdded(DzBoneBinding*)",
"boneBindingRemoved(DzBoneBinding*)",
"boneBindingListChanged()",
"weightsChanged()",
"weightListChanged()",
"blendWeightMapChanged()",
"assetModified()",
"assetWasSaved()",
"normalized()",
"bindModeChanged()",
"generalModeChanged()",
"scaleModeChanged()",
"generalAutoNormalizeChanged()",
"scaleAutoNormalizeChanged()",
"localAutoNormalizeChanged()",
"addBoneBinding(DzBoneBinding*)",
"removeBoneBinding(int)",
"removeBoneBinding(DzBoneBinding*)",
"removeAllBindings()",
"checkAndNormalize(PriorityType,NormalizeType,bool)",
"checkAndNormalize(PriorityType,NormalizeType)",
"checkAndNormalize(PriorityType)",
"checkAndNormalize()",
"normalize(PriorityType,NormalizeType,bool)",
"normalize(PriorityType,NormalizeType)",
"normalize(PriorityType)",
"normalize()",
"normalize(DzNode*,NormalizeType,bool)",
"normalize(DzNode*,NormalizeType)",
"normalize(DzNode*)",
"normalize(DzBoneBinding*,NormalizeType,bool)",
"normalize(DzBoneBinding*,NormalizeType)",
"normalize(DzBoneBinding*)",
"normalize(DzBoneBinding*,DzBoneBinding*,NormalizeType,bool)",
"normalize(DzBoneBinding*,DzBoneBinding*,NormalizeType)",
"normalize(DzBoneBinding*,DzBoneBinding*)",
"convertToGeneralMaps(DzBoneBinding::LocalAveragingOption)",
"convertToGeneralMaps()",
"convertFromGeneralToLocal()",
"buildBlendWeightMapFromLocal()",
"buildGeneralWeightMaps(DzWeightMapList&,DzBoneBindingList&,DzBoneBinding::LocalAveragingOption)",
"buildGeneralWeightMaps(DzWeightMapList&,DzBoneBindingList&)",
"getBindingMode()",
"setBindingMode(int)",
"getGeneralMapMode()",
"setGeneralMapMode(int)",
"getScaleMode()",
"setScaleMode(int)",
"setBlendMap(DzWeightMap*)",
"getBlendMap()",
"reduceWeightMemory()",
"getNumBoneBindings()",
"getBoneBinding(int)",
"findBoneBinding(DzNode*)",
"findBoneBinding(QString)",
"invalidate()",
"invalidateAccumulation()",
"invalidateBlend()",
"findSkin(const DzSkeleton*,int*)",
"findSkin(const DzSkeleton*)",
"findSkinFromNode(DzNode*)",
"findSkinFromObject(int,DzObject*,int*)",
"findSkinFromObject(int,DzObject*)",
"isSingleSkinFigure(DzNode*)",
"modifyAsset()",
"modifyAsset(DzUri)",
"hasGeneralMaps()",
"hasScaleMaps()",
"hasLocalMaps()",
"clearLocalWeights()",
"clearScaleWeights()",
"clearGeneralWeights()",
"invalidateBlendWeights()",
"setAutoNormalizeGeneralMaps(bool)",
"setAutoNormalizeScaleMaps(bool)",
"setAutoNormalizeLocalMaps(bool)",
"getAutoNormalizeGeneralMaps()",
"getAutoNormalizeScaleMaps()",
"getAutoNormalizeLocalMaps()",
"setTargetVertexCount(int)",
"getTargetVertexCount()",
"buildManipulationMaps()",
"Linear",
"DualQuat",
"General",
"Local",
"Blended",
"ScaleMaps",
"BindingMaps",
"RootLowest",
"RootHighest",
"NormalizeNone",
"NormalizeX",
"NormalizeY",
"NormalizeZ",
"NormalizeGeneral",
"NormalizeScale",
"NormalizeWeight",
"NormalizeAll"
[DzBoneBinding()] [ It seems to inherit "DzElement" (not sure):
"objectName",
"name",
"elementID",
"destroyed()",
"deleteLater()",
"className()",
"makePersistent()",
"getName()",
"parentChanged()",
"setName(QString)",
"update()",
"beginEdit()",
"finishEdit()",
"cancelEdit()",
"getLabel()",
"getProperty(int)",
"getDataItem(int)",
"getLoadScript()",
"inEdit()",
"boneChanged(DzNode*)",
"weightsChanged()",
"bindingMatrixChanged()",
"attributesChanged()",
"aboutToDelete()",
"boneParentChanged()",
"setWeights(DzWeightMap*)",
"setScaleWeights(DzWeightMap*)",
"setLocalWeights(DzWeightMap*,int)",
"setBulgeBinding(DzBulgeBinding*,int)",
"setBone(DzBone*)",
"setFigure(DzFigure*)",
"setBindingMatrix(DzMatrix3)",
"invalidateWeights()",
"setLocked(bool)",
"isLocked()",
"hasLocalWeights()",
"hasBulgeWeights()",
"getBone()",
"getBindingMatrix()",
"getWeights()",
"getScaleWeights()",
"getLocalWeights(int)",
"getBulgeBinding(int)",
"getManipWeights()",
"invalidateAccumulator()",
"setFilterByBlend(bool)",
"getFilterByBlend()",
"getScaledOrigin()",
"getLocalWeightCount()",
"FIRST_AXIS",
"SECOND_AXIS",
"THIRD_AXIS",
"SCALE_MAP",
"USE_GENERAL_MAP",
"DEFAULT_AVERAGE",
"FALL_BACK_WHEN_MISSING",
"FALL_BACK_DEFAULT_AVERAGE"
to retrieve a bone weight map:
Do bear in mind that using undocumented methods may be a short-term solution for your own use the fact that they are not documented means they may well be changed or removed without any notice, causing your script to fail. Use them by all means, but do so with caution and an awareness that you may potentialy need to revisit your script following any update.
Yes, thats very true Richard. In my case, the script just helped me took the rigged figure, but I wouldn't use the above methods for a commercial script!
I should put that comment to my posts!!!
