Genesis Handsome Heads
Daily_DoodlerDaily_Doodler Posts: 34
Just installed the above using the DIM on a mac, files are installed into:
users/shared/My Daz 3D Library/data/Daz3d/Genesis/base/Morphs/B9999/B9Handsome
needless to say I can't find the morphs anywhere in the content Library tab as there is no data listing.
Can someone give me enlightenment? Should I just drag the DSF files and their associated PNGs to another folder if so which one?
Thanks, gav
    Assuming that you have users/shared/My Daz 3D Library set as a DAZ Studio Content Directory the morphs will load with Genesis and will add new sliders. If it isn't you either need to add it or to change the isntall directory for the Install Manager by clicking the gear in the top-right corner and going to the Installation tab.
  • Daily_DoodlerDaily_Doodler Posts: 34
    Thanks for the reply as always you're correct once more, was looking in the wrong place for the sliders. Amazing what a walk round the block can do, must try and use this app more often. gav
