Default smoothing itierations?
WilmapWilmap Posts: 2,917
Is there a default setting for smoothing iterations?
Mine seems to be set on 20 and I have to change it every time I use it, usually to about 5. I'd like it to stay at 5 though, not 20.
  • adamr001adamr001 Posts: 1,322
    I believe it varies by item because it is contained inside the dsf/duf file isn't it?
  • Richard HaseltineRichard Haseltine Posts: 102,877
    I think 5 is the default for a newly created smoothing modifier, but the creator could set it to a higher value and use memorise to make that the default.
  • WilmapWilmap Posts: 2,917
    If I create a new modifier it is always set to 20.
  • SzarkSzark Posts: 10,634
    Me too but later this evening I will try Richard's suggestion to see if it works.
  • jepegraphicsjepegraphics Posts: 884
    In DS 4.5 the default value is lowered to 2. It was worked on obviously to not be that dependent from the collision detection.
    2 makes sense as I rarely need to go above 2, thx Jepe.
