upper case letters in windows Runtime
QuickRQuickR Posts: 22
Somehow after I transferred to a Windows 8 system my runtime now has both a libraries and Libraries folder, I sometimes get can't find files errors when loading a model. Is this causing the problem? Is there a way to fix it?
    I would think the best way would be to merge the 2 folders and make sure that it is called library, with a lower case "l"
  • Joe CotterJoe Cotter Posts: 3,259
    If you merge the folders as Chohole mentioned and go to a single capitalization structure (my pref. being proper case) everything will still work fine and you will have a simpler folder structure. Keeping it the way it is usually doesn't cause a problem as the items get found in either one so it may not matter to you unless you have a reason to keep it organized under the sheets or, if for some reason things got duplicated in the migration to Win8, in which case they would take up extra disk space and cause potential problems down the line.
    For what it's worth, older versions of Poser used lower case, more recent versions have shifted to upp case. Zips and installers tend to reflect the version of Poser that was current when they were created (or at least the version that the creator used).
    Ah right. I didn't actually know that. I checked my older version (P8) and it was lower case.
    In my experience installing, at least from a zip, will change the case to match that in the zip - so depending on the vintage of the zip and how it was set up the capitalisation can bounce around.
    edited April 2013
    The case changes when you install? Hmm, that hasn't been my experience. I have always ended up with 2 folders, one lower and one proper.
    Well the upshot is, the installed content can be merged into a single case format without any problems for those that wish to do so.
    Post edited by Joe Cotter on
  • QuickRQuickR Posts: 22
    Thanks to everyone for their comments. So if it will keep happening if I pick up a fast grab or older PC item, I guess should leave it for a while.
    Because if I merge them another item will just recreate the other directory. I don't think Win8 changed the folders, I just noticed after the transfer. Doesn't Win 8 allow case sensitive searches? I think earlier versions of Windows ignored case.
    Every version of Windows I have experience of ignores case - there's no way to get two folders with the same name but different cases in the same location. If Win 8 is different that's new. Linux does distinguish upper and lower case, as does the Mac at least optionally I believe.
    Yes sorry for the confusion. I do work on multiple OS's but the confusion specifically due to these folders is due to me installing single items into a tmp folder and renaming everything there. I haven't actually been loading much into the main folders atm.
    You are right about windows names before Win 8, but now here it is.
    636 x 288 - 135K
    Your libraries folder in lower case is also spelled wrong
    Hey. You are right. You noticed that a lot faster than I did. Thanks. This must be the real problem. Is there a smiley face for way embarrassed?
    yes that is one we do have it's this one :red: lol :coolsmile: j/k
