Lucifuge's Grave glow texture .
AdeyMaCKAdeyMaCK Posts: 0
Lucifuge's Grave I'm having problems with the glow shader , as it does not show up in render.
Is it just a case of applying material file or is their a bit more to it :)
  • fixmypcmikefixmypcmike Posts: 19,582
    Are you using the software (3delight) renderer, or hardware (OpenGL) renderer?
  • AdeyMaCKAdeyMaCK Posts: 0
    Software 3delight,
  • duraluminduralumin Posts: 20
    I'd like to bump this post - I'm having the same problems as well to get the runes to glow - also using 3Delight. Any help would be greatly appreciated, thanks ahead of time.
    If this is the one I think it is, the glowy effect isn't very strong and gets washed out if there's too much light in the scene, dim twilight or night lighting is best. And of course it's only ambient "light", so it's only a glowy-looking effect, it doesn't actually emit light.
    Also, the props are in Poser format and will not look right until you apply the D|S MATs.
    Sorry for my lateness in reply. Just wanted to say thanks for your help. I will definitely give your tips a try!
