Eyes Not Following Camera or Null
Xanadu2000Xanadu2000 Posts: 0
So, I have a long standing issue with D 4.5. Using either Genesis or Gen4, I can load and point the eyes to a camera or null without a problem. Move the camera / null, all works fine. If, though, I save the scene, exit Daz, and then reload Daz and the scene, my characters will no longer following anything -- not the camera, null, or any new item I create. I can "unpoint" the eyes, and then move them manually using the dials, but they will no longer follow an object. The eyes are fixed in position. Does anyone else have this problem? Is there a known workaround?
Using 4.5.1.56 64-bit on Windows 7
Thanks!
  • MattymanxMattymanx Posts: 6,898
    I have seen it happen but was always able to move the null in order to get the eyes to follow again.
  • cwichuracwichura Posts: 1,042
    As this sounds like it is consistent for you, you might consider opening up a bug ticket for it in DAZ's bug tracker at https://bugs.daz3d.com/.
