3D bridge install error...
anise_leinen_390fa63a2b
Yes, it's yet ANOTHER dumb question... :)
I'm trying to install 3D Bridge on 64 bit Windows, but I keep getting this error.
It just won't install the thing...
It happens very early in the process. Has anyone ever had to deal with this one?
It sounds like it could be a corrupted download, what size exactly is the EXE file that you have downloaded?
I just downloaded this file, and it says : 7.05 MB (7,397,376 bytes) for the Size on Disk. Is yours the same?
I see you are using the second version that you have downloaded, are the files exactly the same size? You may need to clear your Browser cache, and try re-downloading
EDIT:
By the way, there is no need to use Photobucket, you can add images directly to your post by using the 'Browse' button just below where you type your post. No need to resize the image, the forum software will do that for you, much simpler.
Yay! It worked!!
Thanks so much. :)
You are most welcome.
