Destination Folder
Lonnie DudeLonnie Dude Posts: 45
I'm installing content the old fashioned way using the Bit Rock installer , .exe files. The little icon to browse for the destination folder is missing. In older files, the little icon is present. is this a Windows 7 issue or has the ability to browse for folders been eliminated? Sometimes, I don't type in the destination correctly and have to manually move files, whichis a drag.
Thanks.
    Are you using a larger font size than the default? That's the only time of heard of this happening on Windows.
    You can create a text file with the correct destination, and copy/paste to the installer field.
  • Lonnie DudeLonnie Dude Posts: 45
    i willcheck my font size. the copy and paste is a good idea!. thanks.
  • SzarkSzark Posts: 10,634
    On Windows Vista/Win 7 (that is all I know) it is easy to copy the destination path
    Go in to Windows Explorer and open your content folder and do as I show in the image below.
    1167 x 505 - 392K
  • Richard HaseltineRichard Haseltine Posts: 100,555
    You can also click in the box for the path, then press the tab key to move to the next control (the browse button) and hit the spacebar to press it.
    thanks. the font size was the problem. But I didn't know about the copy address tip.
