My Renders, Now I can go to bed
KInda decided to keep the title close to the same as before
took a break from my pouting, here is what I did today
one in default, second in Cartoon shader, and last 2 playing with Gimp
778 x 778 - 107K
778 x 778 - 301K
778 x 778 - 341K
778 x 778 - 316K
Post edited by XaatXuun on
Nice renders. Thanks for uploading. The second to last render looks pretty. The scene looks like you took a photo of the model in a sunset.
I didn't get to finish with post work original from Render then some postwork , kept messing it up so ended up with a old photo look
ETA: it's the last image that is original render with no PW
I like your concept....I think if you can add some light at low intensity with the addition of shadow you would get the impression of more depth to your artwork.
Keep up the good work my friend.:coolsmile:
thank you
I was trying to get that trough postwork, but was not getting any the results I was looking for, in time, I'm still learning it.
Don't worry my friend......we are all learning something every day. That's what makes this hobby so much fun. :coolsmile:
Been a while that I even opened up DAZ , so last night I was creating a Character I play on a Online game 'The Secret World'
I need to find the textures for the pistols .. I was too sleepy to find where the folder they re in , so did the render while I rest
It's still WIP
No Post work started . . . Yet
yet again , it's been a while. My HDD died on me a few months back, having to re-download and re-install
did this while taking a break from downloading and installing and playing online games
need to figure what to do about those Eyeballs, not sure I'll get back to this soon, need to do something about those Eyeballs,
way past my sleep time, no Post work, not till I figure those eyeballs out, probably ruin it .. I'm just bad at post work
ETA: okay did toy with it quick like in GIMP, so going to add that here
something I whipped up tonight, cheated and used the Uber lighting and not my own . . should have done a spot render , then would had noticed it was too bright on the left hand
I have some more ideas what to add, so might not be finished yet
think I'll try a different skin for the female, was doing just that then crashed, so posting what I have do so far, and try again later
like the work you did on this .
getting closer, spending more time restoring after crashes then it takes to render this
I think I might have the lighting corrected, but got a error, while making some minor adjustments
For now this is what/where I'm at. maybe later I'll get a render of what I want
Thank you . . it did keep me awake longer then I needed to be
was getting nervous, just as I was able to get the lighting on this one, it crashed . . well now you know what the others were pointing and on guard about . . I'll get to that one, I really want to get it almost finished . . not sure if my machine could handle adding a scene , but I'll give it a shot, maybe I can get lucky
I see many things need adjusted now . . I was holding my breath the whole time of this render . . was scary, with the many other times it had crashed at 80%.
still some more tweaking on the lights too.
have to say I'm happy with the results so far .. not reached that totally happy part yet
have most of what I want downloaded again, so went venturing to what has become available since I last looked, and saw the SOTO flat top . had to get it and whip something up quick so I could use it
Found some more freebies , needed a new model . so I dialed in "Cin"
I'm not happy with the lighting yet, just had to stop and take a break
played with Cin a lil more, trying different skins
no name yet, just some gurl for now
I decided to do a larger render, sure can see more imperfections when the image is larger
Something I did the other day, just now remembering to post it
Sharah
something I did today
Myra
3 different skins, 2 different hairs
first one was some weird thing happening, I was trying out the uberEnvironment 2
Melanie
I did smudge out the nipples, that were poking through, only Post work
Yeah, I'm still learning the uberlights
something
had no connection to the WWW, so had time to get some renders.
well, been playing with the UberEnvironment lighting , but cannot render what I want to, due to old machine. keeps crashing, this is one that did not crash on me, and still needs better settings
Stacy
Judy
skin color didn't come out like it normally does, will need to adjust that
yay . .:-) I happy because I be getting the settings closer to getting the renders I want, and not crash . . still need render dials adjusted, least now I'm closer and can fine tune it
Darby
only have her Head done, it's still WiP for the body
Tracy Teen
Still WiP
down loaded this glass shader a few days back forgot about it, installed now, and did a quick render to see how it turns out
came out great, I didn't do anything but selected the shader.
I'm sure some adjustments would produce better results
found the shader in the free forums http://www.daz3d.com/forums/discussion/26564/
opps . . really want to show this, but with better lighting .. too dark .. so here's a WIP
I have another of these 2, but they are nude, lighting in there also dark but looks cool, I will not post that one
