I'm probably out of luck here
bashrag_7b41cbcd6dbashrag_7b41cbcd6d Posts: 71
Is there a utility that can pull all the files in a scene so that they could be packaged? If not, then is there a way to get a list of all those files?
Thanks
  • LoaarLoaar Posts: 0
    The new .DUF file in the DAZ4.5 RC should give you a list I would think?
    I haven't actually installed it yet, but as I understand it, in theory that should work?
    Remember that you can't package and share content that isn't your own creation, unless the license explicitly allows redistribution. A .duf file avoids that by including references to the content, so that it will open correctly only if the destination system also has the files installed.
  • bashrag_7b41cbcd6dbashrag_7b41cbcd6d Posts: 71
    I'm just trying to transfer scenes between my home computer and my work computer without having to transfer the entire runtime. I can't do that because I have limited shared space on the work system.
    Any clues as to what I'd need to do? I'm pretty sure just transferring the /content directory isn't going to work. In particular the work system is 32bit Vista and the home system is 64bit Win 7.
    OS differences shouldn't matter, but you are going to have problems if you want to do a selective transfer. I don't suppose you have an external drive, that you'd be able to use n both systems, that would hold your content?
  • adamr001adamr001 Posts: 1,322
    You pretty much have to have identical content on each machine. If you're certain you have that, you can fall back to sync utility or even xcopy with the archive bit to copy only changed/updated files. Without base-content in common though I can't think of an easy way to do it.
  • Kendall SearsKendall Sears Posts: 2,995
    I have this feature on the list to add this to my .duf utility. Effectively collecting the files from the data directory and runtime directories and creating a single archive that can get written to a CD-R/DVD-R for archival.
    Kendall
    [quote author="Kendall Sears" date="1339772369"
    Kendall
    Something like that would be awesome. :D
