Scripts menu (custom action dropdown) Scrollbar?
in New Users
I haven't gotton to that point yet, but I'm really liking the Scripts menu for loading everything from Render settings to characters to presets and I can forsee the dropdown growing beyond the limits of the main window, will this dropdown eventually trigger a vertical scrollbar?
Or, is this a scriptable element?
Just thought I'd ask, it's such a handy feature for things that -optionally- depend on one or more presets, much easier than scrubbing through several directory trees to locate items and presets etc. that go together, a scrollbar would be perfect, especially considering the Scripts menu is a user-facing feature.
I've nott ried loading the meu tot hat extent - before getting there I would use Window>Workspace>Customise to split the list into sub-menus or move the commands to other menus (e.g.g put a sub-menu for Render Settings in the Render menu). You can drag-and-drop in the Menus tab on the right to move, right-click to add new top-level menus or sub-menus.
Thanks and, yeah, the submenu setup is the prefered way to go (I use 4.9, btw).
I discovered in my travels that I could set a top-level menu as long as I preficed it with a [&] (taking care not to name it beginning with any chars in use), just using chars did not work (although it should have).
As for creating a sub-menu under Scripts, that sorta worked from the UI, but regardeless of what variation I tried, it failed to take a name other than the default [New Menu], would not even rename after the fact (apply and accept).
But I liked your idea too much to let it slide, so found the dsx file that handles the menu and just edited it by hand in notepad++.
So that works, albeit with some manual editing, now as far as dragging items from Scripts into my RenderSets sub-menu, that does not work, so I'm still in hand-edit mode for that stuff (which is ok, I just want the functionality regardless of the inconvenience).
One more thing, I did try overloading the scripts menu, it just kept on growing right past the main window (my window was set smaller than fullscreen) and nary a scrollbar did appear, so your suggestion is the only way to go in this case.
Anyway, thanks again, I learned a lot.
I should add that even with using sub-menus, we still observe the rule of 'diminising returns' without a scrollbar, in that each level reudces the capacity of the sub-menu by it's root position on the dropdown, so ultimately, there is a hard limit on what you can put in there. Allowing scrollbars on sub-menus might be a fix worth considering.
I did not know this, this is a very useful bit of information thank you!
