Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Update, I've notices Y-axis rotation value change from -176 to 176. Changed it toi -176, the figure is not flying so far. Let me see what comes out of it.
I am pretty new at this as well (November) and was having a horrible time trying to do Posing and Animation. The best tip I came across is to look at mcasual's scripts and utilities.
https://sites.google.com/site/mcasualsdazscripts/
One of my favorites is mcjAutoLimb
It will try to keep a chosen limp where you want or move it towards a specific location. I'm still practicing with it. I think once you have these tools it is case of practicing a lot. Some of the things that were killing me in the beginning I can handle without a problem now.
If you look at post at the end of my thread on "Posing Assistance Please" you will see the list of mcasual's script that I am already using.
https://www.daz3d.com/forums/discussion/220566/posing-assistance-please
He is very active. I asked him a question on January about why his mcjHoldOn script didn't have an animation range like some of his other popular scripts and he actually added that feature and had it up on his site within a couple hours.
Hey poorman_65
Thanks for the tip and link. I checked this out before. I don't believe that would help my problem though. I seem to be missing something essential that prevents me from finishing my project. I guess by now I narrowed it down to be able to move the Hip value more than 180 degrees.
Ok, good:) Keep us posted;)
It seems like I can't do it without turning limits off. Therefore, I will do the walk piece separately. I will then save the walk poses in Puppeteer and import them to the main scene.
I guess I spoke too soon..
Ok so the hip rotations are the problem, so now we know that. Since the hip centerpoint is not at the floor level any other rotation than y will make the legs slide all over the place. As I suggested earlier the only way to go is to translate/rotate the figure using the root node which centerpoint is at floor level. DON'T rotate the hip! Only use the hip for VERY small (corrective) translations for the movements between the main keyframes. And, as I also said earlier, For EVERY keyframe related to figure movement create keyframes for ALL the sub nodes: root node, hip, pelvis, thighs, shins, feet, toes etc. That will more or less eliminate the sliding of the legs. The keyframes must be complete, you must record all rotations and translations for every key! For that I usually use the + button in the timeline but it can also be done in keymate. I usually create the main keyframes first: Sitting on chair: Select the rootnode and expand it in scene tab and select everything from the hip down and press + button, done. Go to Standing in front of chair and repeat, go to 1st step and repeat. You get the picture? When done and you have the whole sequense main frames ready start creating the in between keys using the same method. Lastly create the torso/ arm/head movements and expressions when the walk is working.
The problem with rotation can be solved if you understand how DS is thinking. Create a cube primitive and make a test scene, pretend it is the root node, try transforming it and rotating it around the chair. Start with it being zeroed at 0,0,0. Make next main keyframe and click + to record the key. At some point when rotation exceeds 180, say 270, DS sees it as -90. Therefore you have to dial in 270 in parameters/general/rotations or it will spin the wrong way. Well something along these lines anyway=) So I suggest you try with the cube to make it as easy as possible so you can see how it works. Then use that technique on your G2F rootnode and go from there.
This is certainly only one way of doing it but I know it works for me, and I made a rough test using a G2F and a chair and could make her go around the chair without spinning all over;) Cheers!
ETA: If someone has a better way of doing it, please chime in;)
You can use Memorize and Restore action to fill in the keyframe gaps in the timeline. Select the whole figure or parts of it and memorize on one frame and go to some other frame and paste the current values of poses or also morphs on another frame. With the figure nodes you have choosen / selected - I would press F5:Memorize / right-arrow (next frame) / or Ctrl+right-arrow (next key-frame) / F6:Restore for all frames I want.
I have Customized DS see my thread Customized Main-Menu - Extended @ How to Customize Daz Studio
...now i have the Actions on hand with the:
F4:Memorize | F3:Restore : Figure -and- F5:Memorize | F6:Restore : Item Keys - remember to select children first if you want to have a custom selection of children nodes / bones - someone could also use shortcutkeys for that Select Children action - but the right-click menu on the node of choice within the figure bone hirarchy list in the Scene pane will do the job just fine.
DazStudio interpolates everything (not always like you want it)
Again I think you get strage movment because DazStudio interpolates with the default TP..? settings change that to linear on the hip keyframe(s). Maybe have a look at graphmate.
Here I have a good tutorial video for that: https://www.youtube.com/watch?v=exjHJXAB8nA&feature=youtu.be
Edit_2: To get the animation right you have to take care of the right curve shape - the tutorial video 1st shows a custom animation curve with adding more keyframes and 2nd the problem with unwanted default interpolation settings and how to fix that by changing the keyframe(s) to Linear interpolation mode.
Have another place for the Figure root node (body center point)
Another Idea I once had was to open the Edit_1:
geometryJoint Editor and changing the root node / body center point usualy on the floor to the same as the hip position, created a new Property and saved that new rig-setting to the Property by using ERC-Freeze. But then if you use move (drop) to floor Ctrl+D the figure uses the root node center point to drop or heighten it to the floor level.My suggestion of a Main Figure Group
Maybe one could use a Group first create then parent the figure - always a good idea while working with figures and clothes to turn all visibility on them on and off with one click at the eye icon in the Scene pane.
Next create a Null and let the Group, with the figure parented, Point At the Null and get the point direction fixed with the Joint Editor on the Group. I cant tell in which direction (axis) the Group would usualy Point At the Null - proppably its the +Y-axis by default for Group(s) and Null(s) - check the Joint Editor center/end-points for that and then use "Memorize Selected Nodes Rigging".
With that your figure should then always point its front (face) / walk direction to the Null during animation (let the figure root node be zero) - take care to keep the Null on floor level if you dont want to do crazy backflip jumbs or something ;). You could also use the "Lock" on selected Properties in the Parameters pane in Edit-Mode - in case of the main Figure Group you can Lock some of the Transformation(s) (Rotation X/Z or Scale) or other Properties on the figure(s) that you dont want to change by accident or by loading PreSets (Pose) from the library to the figure(s). Or even "Using Limits" on the main Figure Group Transformation Properties - while setting Min/Max values both to zero - to prevent other issues with Point At.
Guys, you are awsome! Thank you for spending your time and compiling all those recomendations. Since I am 90% done with the project I think they will help me to finalise it. I'll keep you posted.
One hint from another thread:
I wouldnt use Puppeteer - instead why not 1st save yourself some figure poses of the main sitting / standing ... poses in your animation.
2nd then you can also use the Save Pose Set to save animations with the option in the upper part of the save dialouge.
3rd use a plugin I may have suggested earlier http://www.pilning.net/PoseItPlugin.pdf to blend between the sitting and standing pose and then do the "walk in a circle" around the chair animation.
Here are some similar threads I posted in to help dash2128 with animation problems.
Once the figure animation is done maybe you need some cool camera movments?
If you start to set keyframes on the camera(s) you may also get issues with that the cammea(s) starts to spin like crazy - i've read a post somwhere - again some interpolation issues happened there with the camera keyframes default and wrong interpolation not easy to have smooth camera movement paths during animation.
Also notice the little hint I wrote in the screenshot @Camera Tracker on the Point At function and how to handle the Z-axis rotation with "Using Limits" On while setting Min/Max values both to zero.
For that have a look at:
Camera Tracker: with Poit At Null Object for dynamic Camera Focus including Rigid Follow Nodes @ Animation Tools
For more info you may also want to have a look at these threads and my posts here:
Daz 3D Forums > General > New Users > Clearing the Timeline
Daz 3D Forums > General > Technical Help (nuts n bolts) > Animation Tools
ERC-Freeze @_@TUTORIAL - Creating a Genesis/G2F/G2M/G3M/G3M Full Body Morph for DAZ Studio Pro 4.6 by RKane_1
Edit_1: Some of my Bookmarks more or less related to this threads subject:
AniMate: How do I pause animation and advance one frame at a time? 96 views 7 comments Started by JonSea31 Nov 2017 Most recent by Syrus_Dante November 2017
The single most useful feature needed in the next Daz Studio 467 views 14 comments Started by father1776 Nov 2017 Most recent by Syrus_Dante December 2017
How do you switch between orbit and pan in the perspective cam? 71 views 2 comments Started by Brycescaper Dec 2017 Most recent by Syrus_Dante December 2017
Placing characters away from the world center 121 views 7 comments Started by retiretomaui December 2017 Most recent by DDCreate December 2017
Floor Grid 174 views 11 comments Started by leo04 December 2017 Most recent by Syrus_Dante December 2017
Is there any way to import animations to Daz? Please share your workflow! 91 views 2 comments Started by Sunnydays Dec 2017 Most recent by Sunnydays Dec 2017
Posing Assistance Please 112 views 4 comments Started by poorman_65 December 2017 Most recent by poorman_65 December 2017
How do I parent objects or attach for animation? 68 views 4 comments Started by Brycescaper December 2017 Most recent by Syrus_Dante December 2017
Suddenly unable to pose a figure by clicking on various body parts 59 views 5 comments Started by Blind Owl December 2017 Most recent by Blind Owl December 2017
Camera Insanity 230 views 8 comments Started by Martin Leufray III January 2016 Most recent by Syrus_Dante December 2017
adjust property "Use Limits" in script [SOLVED] 46 views 5 comments Started by jerickson.jel January 3 Most recent by jerickson.jel January 3
Documentation Center: » Old ArtZone Wiki » Public » Tutorials » dazstudio » Simple Camera Rotation Setup
Daz 3D Forums > General > Technical Help (nuts n bolts) > Please help with Rotate tool issue
Daz 3D Forums > General > Daz PA Commercial Products > 360 Rotating Turntable Animations
[PS] maybe I should start a thread with all or some of my 278 Bookmarks and categorize them by similar thread subjects - it would be a thread to stick it on some main forum named something like "Before you post read here..." or to copy paste lists of bookmarks to the end of your own answer post - to show threads where questions already have been aswered.
In best case it would answer following up questions the thread opener didn't yet think of or other readers may come up with.
Hey Syrus_Dante
That's some profound work you've done. I will try to get to the links to update my knowledge. Meanwhile I have started over for the 100th time. I recall Sven suggesting earlier to do the walk cycle and then make the figure move around. This seems to be working, just need to master the movements. I will definetely post what came out ofthis whole thing. Thanks again!
I found another reasonable link:
Edit_1: and some other ones related to Animations (in random order):
Can someone point me in the right direction for animation? 1.9K views 48 comments Started by tring01 August 2015 Most recent by Arnold C September 2015
Curve Animation Editor for DS4 1.5K views 9 comments Started by omedhue_196e22b81c June 2012 Most recent by larsmidnatt October 2015
Is there a Walk Designer for DAZ Studio? 421 views 13 comments Started by M Sconti April 2017 Most recent by Ruphuss April 2017
DAZ importer for Blender ( version 1.2) By Thomas Larsson 5.5K views 61 comments Started by kitakoredaz December 2016 Most recent by Padone July 2017
Daz and iClone 7 1.7K views 32 comments Started by tring01 June 2017 Most recent by Padone July 2017
How to export a DAZ figure in fbx format preserving high resolution and etc. 3.6K views 10 comments Started by G-Mer September 2015 Most recent by ousmane.affan_53dc0d3389 June 2017
Genesis 3 skeleton 320 views 7 comments Started by adam_gragg May 2017 Most recent by adam_gragg May 2017
V4 Pose Converter for Genesis 1 & Genesis 2 Female (Commercial) 11.7K views 155 comments Started by Zev0 July 2015 Most recent by Syrus_Dante April 2017
How do I stop a keyframe from affecting another with keymate. 60 views 2 comments Started by Rodrij April 2017 Most recent by Richard Haseltine April 2017
Bake to Transforms or Morphforms to Transforms (.dse) nothing works 214 views 4 comments Started by Syrus_Dante May 2017 Most recent by barbult July 2017
Solved! Using Aniblocks With Scaled Characters 94 views 2 comments Started by Inkubo June 2017 Most recent by mindsong July 2017
Questions about clothing following a figure 50 views 4 comments Started by Ptrope December 2017 Most recent by Syrus_Dante December 2017
IK issue- need a hand fixing my hand fixing problem! 87 views 14 comments Started by marcussrjbates_b1589f87c6 December 2017 Most recent by Sven Dullah Dec 2017
Clear all animations 175 views 7 comments Started by Toonces May 2017 Most recent by wolf359 May 2017
Question about "Point at" feature regarding skirts 77 views 2 comments Started by JonSea31 December 2017 Most recent by Syrus_Dante December 2017
how to rotate both arms together without grouping? 69 views 4 comments Started by itilmau November 2017 Most recent by Syrus_Dante December 2017
Facial expressions.....can they be saved? 1.4K views 12 comments Started by derekmccaughey2010_a63ad0a6ab August 2013 Most recent by Richard Haseltine Dec 2017
Is mimic live junk? 447 views 15 comments Started by michaelolson May 2016 Most recent by wolf359 June 2017
For my fellow Animators using Mimic Live 489 views 19 comments Started by wolf359 September 2016 Most recent by NSFW December 2017
Off topic threads ( here I first start to post my Bookmarks in random order ):
I hope DAZ Studio 5 has better animation support 1.6K views 42 comments Started by christopher-2607496 December 2016 Most recent by takezo_3001 October 2017
Animate DAZ with iClone 6 - REFERENCE GUIDE Announcement Closed
Animation Help Topics and Tutorial Links Announcement Closed (my very first Bookmark Started by DAZ_ann0314 May 2012)
Is it possible to move the key-frames in the timeline? 179 views 7 comments Started by D. Arnaez April 2017 Most recent by wolf359 April 2017
'Eggsplat' for Daz?
69 views 2 comments Started by Toobis December 2017 Most recent by Syrus_Dante December 2017
Feature suggestion thread? 62 views 8 comments Started by JQP November 2017 Most recent by Richard Haseltine November 2017
Problem with items moving in Scene tab 133 views 14 comments Started by straitjacketsonwomen February 2017 Most recent by straitjacketsonwomen May 2017
Parenting item without scaling? 94 views 3 comments Started by AlienRenders April 2017 Most recent by AlienRenders May 2017
Daz Studio crashes when I change the "look at" parameter 69 views 5 comments Started by avmorgan April 2017 Most recent by Richard Haseltine April 2017
How do I orbit the camera on one axis only? 74 views 2 comments Started by trey_makaveli April 2017 Most recent by trey_makaveli May 2017
Need Help with the Viewport 266 views 15 comments Started by FeralFey February 2017 Most recent by Syrus_Dante October 2017
Daz3D version of Texture Transfer tool 126 views 6 comments Started by bsheers2003 September 2017 Most recent by bsheers2003 October 2017
Keyboard shortcuts... 515 views 6 comments Started by geoff6 September 2016 Most recent by Syrus_Dante October 2017
Hotkeys for directories? 67 views 6 comments Started by twalling December 2017 Most recent by maclean December 2017
Is there a way to create shortcuts? 260 views 11 comments Started by Divamakeup October 2017 Most recent by Chohole November 2017
Convert to SubD script 281 views 24 comments Started by Hellboy September 2017 Most recent by Syrus_Dante December 2017
Matching collar to cat 54 views 4 comments Started by whitehorses101_eb09c4df78 December 2017 Most recent by Syrus_Dante December 2017
A morph mask field / moving morph 91 views 4 comments Started by bumbumchack November 2017 Most recent by Syrus_Dante December 2017
How to export only selected clothing as an object in DS 127 views 22 comments Started by IsaacNewton December 2017 Most recent by IsaacNewton December 2017
Genesis 2 with 3 additional bones for fat? 203 views 9 comments Started by johann.hesters_2e9dd0ece9 April 2017 Most recent by Syrus_Dante April 2017
Need some Kit-Bash advice 175 views 8 comments Started by DDCreate September 2017 Most recent by Syrus_Dante September 2017
Remove Selected Deltas from Favourites - can't find this function anymore in the new DS version 88 views 2 comments Started by Syrus_Dante June 2017 Most recent by Syrus_Dante July 2017
Adjusting auto-morphs for additional bones 3.4K views 16 comments Started by Richard Haseltine February 2013 Most recent by MBusch February 2013
I need help for daz 3d studio (Viewport Preview during animation) 47 views 2 comments Started by sourcekarachi November 2017 Most recent by Syrus_Dante Nov 2017
Dissappearing hair when view changed 57 views 5 comments Started by barrettjmb October 2017 Most recent by Syrus_Dante November 2017
viewport glitch 45 views 1 comment Started by sabaoeselian November 2017 Most recent by Syrus_Dante November 2017
What to do when a part of outfit collides with another? **solved* 92 views 6 comments Started by jenniferhughey November 2017 Most recent by jenniferhughey Nov 2017
How to save the parameters changes in Actor and etc? 117 views 12 comments Started by artofcharly November 2017 Most recent by artofcharly November 2017
Plugin for Animating Visibility 243 views 13 comments Started by spacecat56 May 2017 Most recent by spacecat56 May 2017
Animate opacity on a texture?? 140 views 6 comments Started by StevieD November 2017 Most recent by StevieD November 2017
How do you animate a texture change? 3.3K views 18 comments Started by Ebajoy August 2012 Most recent by PA_ThePhilosopher June 2015
Mapping Craziness 237 views 7 comments Started by DarkSpartan August 2015 Most recent by mjc1016 August 2015
Disable a D-Former without deleting it? 42 views 1 comment Started by Illidanstorm October 2017 Most recent by Richard Haseltine October 2017
D-Formers don't transform well when parented to bones 54 views 2 comments Started by Rezzer May 2017 Most recent by Rezzer May 2017
DForm + Face = Sad 120 views 3 comments Started by JamesJAB May 2017 Most recent by Rezzer May 2017
Teeth: Individual Manipulation? 237 views 13 comments Started by tantrumm May 2017 Most recent by tantrumm May 2017
(SOLVED) How to make clothes follow d-formed body? 65 views 2 comments Started by RobertDy November 2017 Most recent by RobertDy November 2017
Soft body physics possible now? 923 views 15 comments Started by d3duser October 2017 Most recent by Quasar November 2017
Are dynamic wrinkle maps possible? 238 views 8 comments Started by klocktimer September 2017 Most recent by Syrus_Dante October 2017
Generated Normal Maps, Causing Seams 68 views 2 comments Started by blackrockhorizon_f39c665403 May 2017 Most recent by Richard Haseltine May 2017
Soft Body dynamic hack using Dforce, deformers, and rigid follow nodes 356 views 4 comments Started by spearcarrier October 2017 Most recent by spearcarrier Oct 2017
mcjElasticSim - much awaited script for verlet based dynamics ( bounces ) 1.6K views 28 comments Started by mCasual Oct 2016 Most recent by spearcarrier June 2017
Ok thats all I can offer for good Bookmarks - Please feel free to share your own Bookmarks if you find them useful for others.
To post the above I did go here Daz 3D Forums > My Bookmarks searched the thread title with "Browser text search" Ctrl+F - then activated the "Insert/Remove Bulleted List" here in Post Edit mode - and simply copy / pasted some of my Bookmarks to this thread list with "mouse text selection" (you may have to enable in Browser settings) - next Ctrl+C then "browser tab switch" Ctrl+Tab next Ctrl+V - done. This was done in no time.
[PS]: I would suggest: tread every new thread with a meaningful question in the title as a place to redirect questions and forum users.
One last hint as a workaround for the forum search: most people come here because Googlebot (Link to https://en.wikipedia.org/wiki/Googlebot) found reasonable search results in the Daz forum posts. Following Wiki Links: Google Search Console / Google Blog Search
You can start your search like this:
Greetings
Syrus_Dante
Edit_1: I've UPDATED my Bookmark list in my previous post.
"Ok, in case anybody is interested...I throw the white flag on this. "
I'm sorry to hear it didn't work out for you! As I said it was not an easy task to take on but you at least solved the biggest issue with the flying around so well done:) Hope to see you back in the future and good luck with your project!
Thank you Sven! You've been the greatest help since the very beginning of this ordeal.
GETTING THERE! Since my last post I decided to have another go at this and something had started working out. What I did was:
1. I deleted the keyframes where the problem started occurring
2. Animated a straight walk without turns carefully watching all the body and hip axis
3. Set the end point for the Y rotations and xyz translations.
It started taking some shape. Please see
I am struggling with the sliding feet now but it's a different story and I know volumes have been writtin in the forum about it. Any ideas how I can improve this? Thank you all again!
Wow that made me happy
! Very well done mate! I'm afraid there are no shortcuts though, only hard work lol. You need to adjust the leg rotations to sync with the figure/hip translations, zoom in on her feet and jump back and forth between keyframes and adjust legs until the foot she is standing on stays in the same place. You're halfway there my friend!
Thank you Sven! Halfway, though...:) Ok, I'll keep on working. I see the light in the end of the tunnel
Hi everyone, thanks again for support. Please see the outcome of my deliberations. I couldn't ahieve the grainless quality but it's the first one so...
Thank you so much for sharing!
Thank you! My major issue was the movement, rememeber? I ended up buying the sexy walk ^) but still had trouble with sliding feet. The issue with smooting modifer could have been caused by the fact that the outfit is for V4 and it's a G2 figure. I've done a ton of reading about lighting but couldn't get to a better result trying to balance time vs quality. Overall rendering took 16 hrs for the figure animaiton only. I set the Max Time/Iteration values to very low. Otherwise it woud take me days to render. Any suggestions? Also I couldn't figure out body morphs on the hard surface (chair) other than just dipping it lower.
Well have you considered rendering in 3DL, you would probably get a sharp and grain-free result much quicker. That's one main reason to why I use 3DL exclusively;) When rendering animations I usually manage to keep rendertimes under 1 min/frame with 1080p resolution.
Hmmm. Never thought of that. I'll try my next render with it. Thanks
