Tex Jones presents
![texjones](https://secure.gravatar.com/avatar/45c6d05bb82e1ef7962be6e14d0d815c?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F45c6d05bb82e1ef7962be6e14d0d815c_100.png)
And so here it is...finally finished. Took almost a month to do. This was a real learning experience as I progress through it. Working with Daz and tightening up my animation skills. My 32 bit for some reason won't bring up the scenes I create in the 64 bit. So I had to do the lip sync manually, which was good as I learned to tighten up on that animation. I took the soundtrack into Flash and counted the frames-both Flash and Daz running at 24 fps. When Wimpy carries Brutus, I had to dictate that frame by frame. Took the aniblock and puppeteered each frame then set up a formula so the arms and head and eyes would be in correct position in each frame.
So much I learned as I progressed and it was a lot of hard work, so aggravating at times. But I LOVE doing animation. Thanks to Daz. Where were you 30 years ago???
Are you sure this is the thread you wish to discuss this in? I think the Animation Forum would be a better home for this.
If you like it can be moved for you.
ok, but I don't see an Animation Forum...
Right here... http://www.daz3d.com/forums/categories/42/ under the General Forums
I can just move it for you if you like.
This is something I've wanted to do for a long time. It took just about a month to complete. As I progressed through the video I Learned so much more about working with Daz, Hexagon and just tightening up my animation skills.
http://www.youtube.com/watch?v=l3otP2XI7P8
OK, I just re-posted it in the correct forum, but I can't delete this one...
Duplicate threads merged.
...in the wrong forum...? ;-) or buggy code?
