How to make light rays?
P-O-MP-O-M Posts: 29
Hey guys,
Im trying to add light rays in DAZ studio, any chance in directing me to how to do it?
On more thing I'm trying also to create a light bulb, that simply glows.. im a noob so go easy on me ;)
Roy.
  • TotteTotte Posts: 14,087
    A glowing bulb can be achieved in two ways.
    (a) Set the Ambient to White or Yellow and then set the Ambient to at least 100% (you can remover the limits and go even higher)
    (b) Using the omnifreaker Arealight shader and apply that to the bulb surface.
    Rays are more difficult unless you use a volumetric camera, but there are ways. A simple way it to use a built in default mesh, the cylinder, size it and then set a almost invisible surface (using opacity), and Ambient)
    edited April 2013
    You may be able to do something similar to this, Light ray made using a cone primitive stretche and a tex mat fed into the ambient channel which is shaded and then ambience was set at 100% Has the diffuse channel at zero and pure black, the texture drives the transparency to give the shading effect.
    900 x 675 - 389K
    900 x 675 - 97K
    Post edited by Chohole on
  • P-O-MP-O-M Posts: 29
    edited April 2013
    Thanks for trying to help out..
    Most of what you said looks a bit of Chinese to me like I said in a total noob to the software.. ill try my best..
    Roy.
    Post edited by P-O-M on
  • Scott LivingstonScott Livingston Posts: 4,344
    edited April 2013
    DAZ Studio includes UberVolume, which is one way to achieve a real volumetric effect (light rays, for example). This thread, and the links therein, contain a lot of good information on using UberVolume. It is a bit of a challenge for a new user, but not impossible. :) http://www.daz3d.com/forums/discussion/17730/
    For the lightbulb, this thread may be a good resource: http://www.daz3d.com/forums/discussion/14536/
    If you need help with the terminology, there's a glossary here: http://www.daz3d.com/forums/discussion/46/
    Of course, if at any point you get stuck, feel free to post questions here. The forum can be a great resource.
    Post edited by Scott Livingston on
  • Mustakettu85Mustakettu85 Posts: 2,933
    One of the examples in Shader Builder (not the Mixer) is "Glow" - just compile it and apply to a cylinder surface. Turn down opacity to zero, pick your diffuse colour and adjust the "attenuation" to taste - it is like a fancy ambient with falloff. Just make sure the top and bottom faces of the cylinder are behind something or out of view - they will look like circular cutouts in your glowing ray =)
  • JaderailJaderail Posts: 0
    edited April 2013
    The easiest way to do Light Rays in DS4.5 is with this...
    http://www.daz3d.com/atmospheric-effects-cameras-for-daz-studio
    I hope this helps, it helps me when I need God Rays.
    Post edited by Jaderail on
