wire frames
petes imagespetes images Posts: 213
edited November 2017 in Hexagon Discussion
this may have been asked before so apologies. As a new user to hexagon, how can i hide/disable etc the wire frame until needed, smoothed solid is selected but still showing, i find it distracting at times hence the reason i don't use it in Daz until needed. Sorry should have said i have tried all the versions of Genesis i have
thanks
pete
Post edited by petes images on
  • DzFireDzFire Posts: 1,473
    Eight little balls on the bottom of your screen, select the fifth one.
  • already done that, didn't help
    pete
  • ShawnDriscollShawnDriscoll Posts: 375
    I change the color of the edges so they match the color of the faces sometimes. Colors are the first thing I start configuring when I install Hexagon.
    Post edited by ShawnDriscoll on
    I think I understand now. Go to Edit -Preference editor -3D Display -Selection and uncheck 'Display edges'
    yes but makes figure to transparent, eyes appear to pop out, mouth seems distorted, could be tongue sticking out
    thanks
    thanks
    How many polygons is your mesh? Over 50,000? AA is turned on or off in your display?
  • Is this a figure you've sent via the bridge or did you export-import an obj file. If the former, Hexagon does not recognise Iray, so change it to 3Delight and see if that makes any difference.
    If that does not help, please make a screen grab and post it here.
    thanks
    thanks to all but have decided to give up with it, it will be uninstalled.
    Have a good christmas everyone
    pete
