All Clothing one color
mistysea61mistysea61 Posts: 0
When I try to add the clothing to a Genesis they are white.How do I make the pants black??
  • frank0314frank0314 Posts: 14,288
    You need to apply the material preset for that item. What outfit are you using
  • mistysea61mistysea61 Posts: 0
    edited May 2013
    I am new to Daz and was using the JS Pants the outfits that came with the download.It is telling me it can't find file C:/Users/Documents/Daz3D/Studio/My Library/RunTime/Textures/MAB/M4FarJourner/FJCelticPants.jpg
    Not sure what all this means as My library is there
    Post edited by mistysea61 on
  • Richard HaseltineRichard Haseltine Posts: 102,662
    The [pants load textures for me, so I suspect you are in a non-textured view mode. Click on the little sphere icon almost in the top-right corner of the viewport (by default) and select Texture Shaded from the menu (or press ctrl-9. cmd-9 on the Mac).
    edited May 2013
    There is something wrong with your install. The JPG the program is looking for is just a black square which is loaded into the Surfaces tab to give the black colour. In the meantime, you could go to the Surfaces pane.select the Diffuse colour, and set it to Black, that will do for now.
    In the long term, there is an error in your install of Genesis Starter Esentials, and you may need to reinstall it. Make sure that you are installing it to the My Library folder as the last part of the path, or if using the DIM, make sure that My Library is the destination folder.
    Is that the pnly Journeyer Scout item that is giveing a problem?
    Post edited by JimmyC_2009 on
    No All the clothing is like that.Not sure what is wrong.I reinstalled the Genesis Essentials into MyDaz Library and nothing changed.I also have textured shading on.So not sure what to do next except uninstall it all.
    Everything gives missing files errors, or everything is white? If the latter, do things render correctly? If the former, what folders do you have selected as content directories? You can get the list by going to Edit>Preferences>Content Library and clicking the Content Directory Manager button.
    It says everything is in C:/Users/Documents/Daz 3D/Studio/My Library
    C:/ProgramData/Daz 3D/My Daz Library
    Some How something got messed up during down loading.
    Thanks everyone for your help.I now have it figured out and working again
