Duplicate formula help
assmonkeyassmonkey Posts: 0
I have this Expression folder in my morphs folder (DATA place)
Duplicate formula found linking Value & CTRLFlirtingMasculineR
Duplicate formula found linking Value & CTRLFlirtingMasculineL
I found them and deleted them. The message doesn't come up anymore, BUT I'd open it again to check
I open up the log view, and under the error of the double file...the lastest tells me it can't find the files I deleted from the folder (I moved them to another place to see instead if deleting)
Could not find target property for formula ..... PHMFlirtingMasculineR & PHMFlirtingMasculineL
I also see those, should I also delete/move them? *does it*
Ok, I moved that file, too...now the missing list is longer
telling me it can't find PHMFlirtingMasculineR & PHMFlirtingMasculineL
then it later connecting to saying MCMV5HdFlirtingMasculineR.dsf & MCMV5HdFlirtingMasculineL.dsf
and the other Masculine flirting for V5, S5, M5, H5, F5, D5, A5 (so the Gen 5 morphs were effected)
And I'm pretty sure I can't remove the expression folder. Some file needs to be deleted or something.
Should i just remove all the Flirting Masculine files from them?
I do have the Fix Dup IDs...but I doesn't seem to let me pick Genesis.
My M4& V4 morphs also have some issues
Post edited by assmonkey on
  • SzarkSzark Posts: 10,634
  • assmonkeyassmonkey Posts: 0
    Nope, because I did uninstall the Expression folder, and put installed it back on...it really did nothing.
  • Richard HaseltineRichard Haseltine Posts: 100,833
    Did you redownload the Evolution Expression morphs and install the new version?
    Wouldn't know, can't download anything until midnight. Just used what was on my computer at the time
    The issue is in the content so reinstalling the same files will just bring it back.
  • Mr RidMr Rid Posts: 40
    I have the same 'duplicate formula' issue.
    My log shows the duplicate is also ".../data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Expressions/CTRLFlirtingMasculineR.dsf." I dont know which install this is associated with(?). But a drive search shows that this file only exists in one place. It is not 'duplicated' anywhere (?).
    When installing any Daz products over the years, I always select 'create uninstaller,' but I have never had to uninstall items before. I see the uninstallers are not located where Daz Help https://helpdaz.zendesk.com/entries/20651678-how-to-fix-the-duplicate-formula-message indicates, in "C:\Users\[Your user name]\Documents\DAZ 3D\Studio\My Library\Uninstallers" My "Render Library" folder is empty (should it be?).
    Then I was surprised to search the drive and find there were only a handful of uninstallers in the Uninstallers folder in the Daz content folder. I dont know where they all went (?). Would a new install of DS (when it uninstalls the previous version) remove old uninstallers for some poorly thought out reason?
    DAZ Help lists many potential culprits to uninstall- https://helpdaz.zendesk.com/entries/20651678-how-to-fix-the-duplicate-formula-message
    I am not sure how to manually uninstall all these, and it sounds like a potential mess, and with having to re-associate in Content Manager, etc. Is there no way for me to simply remove or move a suspect file?
    You can delete that Expressions folder, the problem product is Genesis Evolution Expressions, which now installs to the Evolution folder.
