Hi all, I have a problem with Daz3d 4.5Pro 64bit
paul1912011paul1912011 Posts: 0
Its to do with pinning, I pin parts of the body say the hand but the pinning dose not work. It still moves. So I thought it could be a problem with daz3d.4.5pro 64bit so I reinstalled daz3d 4.0 but the problem still remains. The pinning translation and rotation dose not work. I have tried different models including the sub dragon that comes with daz3d
Any suggestions would be great
thanks
  • SzarkSzark Posts: 10,634
    Are you under the assumption the Pinning will fix a body part so it doesn't move at all, ever?
    As with pinning the part that is pinned will move when the posing goes beyond a certain point or limit. it will never be fixed to the point where it doesn't move at all.
  • JaderailJaderail Posts: 0
    There are two methods of Pinning in DS IK pinning and Node pinning. But as Szark points out both will not stop movement if the limits are exceeded. Node pinning is done with the Tool Settings Menu and most often the ActivePose tool.
