What clothes will fit an extreme pear shape V4 body? (Solved)
![lukon100](https://delorean.daz3d.com/forums/uploads/userpics/237/n6MJ02TFS0O4B.jpg)
Nothing I have fits this V4 character because of the extreme pear shape it has.
Does anyone know what clothing assets might fit? A muumuu of some kind?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/b6/2736a16c32ced625c1f61a743921b4.jpg)
1280 x 1024 - 584K
Post edited by lukon100 on
Put a loose dress on her. Go to Edit/Object/Geometry/Add Smoothing Modifier. Go to properties with dress selected, and under smoothing, make sure dress is set to collide with V4. Keep upping the collision iterations until pokethrough is gone.
You probably tried this but use the transfer active morphs function on the clothing after fitting it to V4.
Thanks so much, both of you.
A combination of the advice from both of you seemed to do the trick. Transfer the active morphs, add smoothing modifier, adjust collision AND smoothing iterations for best appearance.
May I ask why you chose to do a charactor that big in size?
Yes.
This character is for a picture I plan to make in which I portray the plight of those who deviate radically from the dominant standards of physical beauty.
