Finding Clothing Morphs for Genesis 8 Clothes
Hello,
So I just recently started using Daz Studio after using poser for a long time and have some questions regarding the morphs for the clothing on Genesis 8.
In Poser clothing would come with a bunch of preset morphs and then once it was conformed to a figure it would match with the values on the figure. If you wanted to you could adjust the morph values ether increasing or decreasing them to get the clothing to fit better. At least that is how it worked with Victoria 4.
With Genesis 8 clothing it seems to copy the morphs directly from the figure in order to get it to fit the Genesis shape. When I view the parameters of the clothing I see some custom morphs the vendor included on the clothing but none of the morphs it probably copied from Genesis 8. I cannot tweek the morph values on the clothing of say "Hip Width" or "Breast Diameter" like I could with Victoria 4 in poser.
Am I doing something wrong? Should I be able to see those morphs and values on the clothing or is the way it works different for Genesis 8 figures compared to something like Victoria 4? Thank you very much for your time and help.
  • LeanaLeana Posts: 11,844
    You might need to "show hidden parameters" in the parameter tab for the auto-generated morphs to show.
  • Hello Leana,
    I right clicked on the parameters tab and checked "Show Hidden Properties" and that brought up the morphs for the clothing.
    Thank you so much.
