mcjInterPose - Daz Studio script - Mix 2 poses using a slider - animatable, multi-figure
maybe someday ( in 2018 ) there will be another version or as as a plugin
The Script >>> https://sites.google.com/site/mcasualsdazscripts8/mcjinterpose
animated demonstration here : https://mcasual.deviantart.com/art/later-today-mcjInterPose-for-Daz-Studio-719084669
The first time you run this script, a new node named 'PoseMix' will be created.
You should then exit this script and animate the 'PoseMix' property of the 'PoseMix' node.
Pose your figure(s) one way at frame 1801 and pose your figure(s) a different way at frame 1802
Select the root node of your figure(s) and run the script again
Select the range of frames to be processed
Press the DoIt button
The script will go frame by frame. The value of the 'PoseMix' slider
will control the the mix between the pose at frame 1801 and at frame 1802.
Note that you can also specify other frame numbers than 1801 1802.
Not sure if the entry in the freebie script list is an accurate summary, will it pass muster? https://www.daz3d.com/forums/discussion/293/list-of-free-daz-studio-script-and-plugins#latest
NEW FEATURES ! ( yes already )
mcjInterPose - New Features - oh my Bob so soon !
you can now specify a step
and can have root-note properties involved in the animation
thanks for still maintaining that list !
on the release page i introduced it as "Mix two poses or even two scene-poses"
a bit like puppeteer but controlled by a "PoseMix" property, so it's animatable
and it can process all currently selected nodes in one shot
someone wanted something like puppeteer but for 2 figures
imaybe in 2018 i'll add a "live" mode.
OK, I'll edit my description. Thank you for all the scripts.
Thanks, Great Tool.
It would be interesting, that it works with puppeteer.
