Issues with Shadows
in New Users
Hello, I'm running into an issue with shadows. I'm trying to do a sequence of images, and after posing and rendering the first few, I have to step away for work, sleep, etc. So I create a camera to save my view positioning. When I reload the last scene and press on, any further renders have a tons of shadows. Is this from the camera or is there a setting I'm unaware of?
Yes, it's called a headlamp. Select the camera in the scene tab, go to parameter tab and switch the hadlamp to "off".
As long as the camera doesn't have a custom override you can switch the headlamp off for all in Render Settings' Editor tab, under General.
Awesome! That was such an easy fix, thank you both very much!!!
