skin problems
akikobazakikobaz Posts: 3
edited May 2013 in New Users
hello. i'm using daz 4.5. i'm trying to do ambient occlusion but when i render the image the skin looks weird. sorry if this has been covered before but i don't know the name of this condition. fyi i used the uberenvironment2 base presets. thanks!
1280 x 1117 - 2M
Post edited by akikobaz on
  • JaderailJaderail Posts: 0
    Samples for the Uber Enviroment are to low. At default (8) your shadowing will look that way. Try one of the Quality presets (IF) UE2 came with any. I use UE which comes with 4.
  • SimonJMSimonJM Posts: 5,980
    You need to increase the 'quality' setting for the UberEnv, either via a preset or manually adjusting the relevent dials (Occlusion Samples up, Shading Rate down, Max Error down). In addition adding another light to the scene will help.
  • akikobazakikobaz Posts: 3
    thank you! it worked. can i use the quality presets with other lighting?
    No they are made for UE. They tweak it's settings.
    okay. again thank you for the help.
