How to put caps on cylinders?
Thanks
Mic
  • Ok I found out that they have to be put on, on creation.
    Mic
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited December 2017
    This came up before, and because I still have the pics I thought I'd re-post the image, you never know someone might find it useful :)
    There are a few ways you can close a hole, the screen grab I had stored shows two.
    1919 x 1008 - 534K
    Post edited by Wee Dangerous John on
  • edited December 2017
    Thanks for the reply John
    In a dedicated modeler should it not just be select the edges and have a fill command?
    Its how itst done in Carrara
    Mic
    Post edited by michael-kristensen_e59faa8f72 on
  • Yes, but when you as smoothing you will come into problems, also you have problems with Ngons. To be on the safe side I always aim for a face made up of 4 points.
  • cdordonicdordoni Posts: 583
    After you set the height for the cylinder, click the "A" .  The white highlighted ends will be capped. The "A" or close function is available in some other operations as well.
    906 x 634 - 106K
    Thanks cdordoni
    Yes... but only at creation
    Mic
  • You still have the Close option in the Vertex Modeling tab. But as I stated earlier, you may have trouble with Ngons.
  • odd I created a cylinder in Hexagon beta to see for myself, I clicked the edge and it filled with an ngon immeadiately so I went to tools tab, vertex modelling and clicked quad tesselation and all was done yes
    one annoying thing missing in Hexagon is a lathe tool, just thought I'd bring that up, had to make wine glass from a cylinder instead.
  • DzFireDzFire Posts: 1,473
    Extrude Line under Surface modeling is made to do that.
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,472
    yes that extrudes it but lathe, a Carrara fuction I use a lot takes an edge and models a solid object around it in the polyline shape,
    I see on Youtube 3D studio MAX also has this modifier
    its great for making vessels of all shapes like weird bottles, bowls and chess pieces
    I know I was frustrated not finding a similar tool in Blender which I am painfully trying to learn too.
    I have not tried Carrara but I think DzFire is recommending the correct tool for the job. All it is doing is taking a profile and running a curve along it to make the object.
    Here's a quick example, I don't normally do videos and I have not finished adding my short cuts hence me staring at the screen looking for the tools :)
    Sorry no audio or subtitles, I can add the latter if you wish.
  • ShawnDriscollShawnDriscoll Posts: 375
    Hexagon has that as well. One of its earliest features.
    And used in Amapi long before Hexagon.
    Post edited by ShawnDriscoll on
  • it is a bit different, more steps but also it appears more options
    I must try it
