Released: Easy Teeth for Genesis 8 Males - Morphs and Controls + MR (commercial)
![SF-Design](https://delorean.daz3d.com/forums/uploads/userpics/729/n5LU2BSTRG1KX.jpg)
https://www.daz3d.com/easy-teeth-for-genesis-8-male-s-and-merchant-resource
The teeth of humans never look exactly the same. Unique characters have different teeth.
Give your Genesis 8 Male based characters some more individuality with adjusting the shape and look of their teeth.
This morph pack contains 122 morph control dials to adjust the teeth. You can adjust each tooth individually. Make them longer, shorter or completely gone to have gaps or adjust their volume. With these morphs you can get many different looks of the teeth for more individuality of your characters.
Included are also morph dials for all teeth, like one to get childish looking teeth or irregular teeth. Morphs to make the upper canines sharp (vampire teeth) are included too.
Rounded up is this product by the included 10 material presets for Iray. Unclean and yellowed teeth, different teeth tones like slightly stained or bleached white teeth, bloody teeth and one preset with gold teeth.
You can of course save all your teeth adjustments as your own shape presets as well to be able to quickly apply your favorite settings later.
Overall a very versatile product to make your characters more unique.
This product works with all Genesis 8 Male based characters.
This product is also a Merchant Resource you can use to create morphs for your character products.
Merchant Resource Usage:
You may bake your own morphs using the morphs (also mix them) included in this products to include them with your own commercial character products. You may also include the morphs directly (altered or unaltered) to your commercial character products. This product is not a requirement.
Resource Usage should be stated in your product Readme. The image maps/materials of this resource may be used alike (unaltered or altered).
You may not create another merchant resource using this resource or a similar product like another teeth morph/control or teeth material only product.
Using this resource for free products is not allowed as well. The main purpose of this resource is character creation. The usage of this MR is limited to Genesis 8 Male based characters.
- Easy Teeth
- Morph Dials (.DSF):
- All Teeth Irregular
- All Teeth Length Reduce
- Boys Milk Teeth
- Vampire Teeth
- Lower/Upper Teeth Length Reduce
- Lower/Upper Central Incisors Gap
- Upper/Lower Central Incisor L/R Length Reduce
- Upper/Lower Lateral Incisor L/R Length Reduce
- Upper/Lower Canine L/R Length Reduce
- Upper/Lower First Premolar L/R Length Reduce
- Upper/Lower Second Premolar L/R Length Reduce
- Upper/Lower First Molar L/R Length Reduce
- Upper/Lower Second Molar L/R Length Reduce
- Upper/Lower Third Molar L/R Length Reduce
- Upper/Lower Central Incisor L/R Longer
- Upper/Lower Lateral Incisor L/R Longer
- Upper/Lower Canine L/R Longer
- Upper/Lower First Premolar L/R Longer
- Upper/Lower Second Premolar L/R Longer
- Upper/Lower First Molar L/R Longer
- Upper/Lower Second Molar L/R Longer
- Upper/Lower Third Molar L/R Longer
- Upper/Lower Central Incisor L/R Rotate L/R
- Upper/Lower Lateral Incisor L/R Rotate L/R
- Upper/Lower L/R Central Incisor Width
- Upper/Lower L/R Lateral Incisor Volume Reduce
- Upper/Lower L/R Canine Volume Reduce
- Upper/Lower L/R First Premolar Volume Reduce
- Upper/Lower L/R Second Premolar Volume Reduce
- Upper/Lower L/R First Molar Volume Reduce
- Upper/Lower L/R Second Molar Volume Reduce
- Upper/Lower L/R Third Molar Volume Reduce
- Shaping Presets (.DUF):
- Reset Easy Teeth Morphs
- Teeth Irregular
- Boys Milk Teeth
- Vampire Teeth
- Material Options (.DUF):
- 10 Easy Teeth Materials
- 03 Gloss Options
- MR Useage Document (.PDF)
- Textures Include:
- 30 Texture, Bump and Normal Maps (2048 x 2048 up to 4096 x 4096)
- Daz Studio Iray Material Presets (.DUF)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/21/f05398a166f296275cd5e5487fdd03.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/6f/0358373182d8d3ee2db0ac15d0e105.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/d4/68c1437708904448af1de4c4c283c2.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/5b/43b134ec5a2b8d13e5b5dab8a4a66f.jpg)
The product has been released today
Get it here: https://www.daz3d.com/easy-teeth-for-genesis-8-male-s-and-merchant-resource
Along the release all my not new items are 40% off right now, including Easy Teeth for Genesis 8 Females and more :
https://www.daz3d.com/sf-design#&filter_new=0&filter_platClub=0&filtered=1
(up to 50% with the purchase of another new release. Daz sale terms and coditions apply)
