Daz4.6 crashes on render
IvyIvy Posts: 7,164
I've been playing around with the new daz4.6 and it seems I can't render it with out crashing the program
I don't receive any error message or anything just poof the program crashes ..
it appears to crash no matter how i set the lighting and it crashes on spot rendering.
the only thing i could find was on the log file. It has done it on numerous scene and sets I have tried using.
I did a complete uninstall and did a clean reinstall and still the same thing happens it crashes on render.
anyone got any Input?
Log I attached.
Rendering image
Compiled C:/Users/Ivy/AppData/Roaming/DAZ 3D/Studio4/shaders/brickyard/{437be9e0-9644-44e4-b9e9-46085b753d69}/shader_Surface.sdl...
Created RenderCacheBlock
Saved image: G:\Documents\Daz\Temp\render\r.png
Finished Rendering
Total Rendering Time: 50.6 seconds
Saved image: G:\Documents\Daz\Temp\RenderAlbumTmp\Render 1.jpg
Rendering image
WARNING: QString::arg: Argument missing: The renderer encounterd a memory error and the program has become unstable.
Please close and restart DAZ Studio as soon as possible.
, www.daz3d.com
    According to this, you are running out of memory. What OS are you using, and how much RAM is there in your system?
    When you run a render (assuming windows) have a look in the Task Manager to see how much RAM is being consumed.
  • IvyIvy Posts: 7,164
    edited May 2013
    I'm not running out of memory that is for sure. the system i load daz4/6 on is a win 7 64byte 3.33 ghz with 12 gigs of ram
    +++++++++++++++ DAZ Studio 4.6.0.18 starting +++++++++++++++++
    Platform bits: 32
    Qt Version: 4.8.4
    Running on Windows 7, Build 7601, Service Pack 1
    CPU Information:
    CPU String: GenuineIntel
    CPU Brand String: Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz
    Cache Line Size = 64
    L2 Associativity = 6
    Cache Size = 256
    Stepping ID = 2
    Model = 12
    Family = 6
    Extended model = 2
    CLFLUSH cache line size = 64
    APIC Physical ID = 1
    Supported CPU Features:
    SSE3 New Instructions
    MONITOR/MWAIT
    CPL Qualified Debug Store
    Thermal Monitor 2
    x87 FPU On Chip
    Virtual-8086 Mode Enhancement
    Debugging Extensions
    Page Size Extensions
    Time Stamp Counter
    RDMSR and WRMSR Support
    Physical Address Extensions
    Machine Check Exception
    CMPXCHG8B Instruction
    APIC On Chip
    SYSENTER and SYSEXIT
    Memory Type Range Registers
    PTE Global Bit
    Machine Check Architecture
    Conditional Move/Compare Instruction
    Page Attribute Table
    Page Size Extension
    CFLUSH Extension
    Debug Store
    Thermal Monitor and Clock Ctrl
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    SSE2 Extensions
    Self Snoop
    Hyper-threading Technology
    Thermal Monitor
    Pend. Brk. EN.
    Physical Memory:
    Total: 3.9 GB (4294967295)
    Avail: 3.9 GB (4294967295)
    Virtual Memory:
    Total: 3.9 GB (4294836224)
    Avail: 3.8 GB (4103970816)
    Current Memory Usage: 18%
    Current DateTime:
    Loc: Sun May 19 22:46:32 2013
    UTC: Mon May 20 02:46:32 2013
    Temp Data:
    Location = G:/Documents/Daz/Temp
    Disk Total: 931.5 GB (1000202039296)
    Disk Avail: 838.1 GB (899933401088)
    Locale: en_US
    No translator found.
    Reading style definition C:/Program Files (x86)/DAZ 3D/DAZStudio4/resources/style/Darkside.style
    Creating managers
    Reading help index
    Reading help file C:/Program Files (x86)/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
    Reading help file C:/Program Files (x86)/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
    Scanning import folders
    Scanning content folders
    Using GLEW 1.9.0
    Supported OpenGL extensions:
    GL_AMD_multi_draw_indirect
    GL_ARB_arrays_of_arrays
    GL_ARB_base_instance
    GL_ARB_blend_func_extended
    GL_ARB_clear_buffer_object
    GL_ARB_color_buffer_float
    GL_ARB_compatibility
    GL_ARB_compressed_texture_pixel_storage
    GL_ARB_conservative_depth
    GL_ARB_compute_shader
    GL_ARB_copy_buffer
    GL_ARB_copy_image
    GL_ARB_debug_output
    GL_ARB_depth_buffer_float
    GL_ARB_depth_clamp
    GL_ARB_depth_texture
    GL_ARB_draw_buffers
    GL_ARB_draw_buffers_blend
    GL_ARB_draw_indirect
    GL_ARB_draw_elements_base_vertex
    GL_ARB_draw_instanced
    GL_ARB_ES2_compatibility
    GL_ARB_ES3_compatibility
    GL_ARB_explicit_attrib_location
    GL_ARB_explicit_uniform_location
    GL_ARB_fragment_coord_conventions
    GL_ARB_fragment_layer_viewport
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_fragment_shader
    GL_ARB_framebuffer_no_attachments
    GL_ARB_framebuffer_object
    GL_ARB_framebuffer_sRGB
    GL_ARB_geometry_shader4
    GL_ARB_get_program_binary
    GL_ARB_gpu_shader5
    GL_ARB_gpu_shader_fp64
    GL_ARB_half_float_pixel
    GL_ARB_half_float_vertex
    GL_ARB_imaging
    GL_ARB_instanced_arrays
    GL_ARB_internalformat_query
    GL_ARB_internalformat_query2
    GL_ARB_invalidate_subdata
    GL_ARB_map_buffer_alignment
    GL_ARB_map_buffer_range
    GL_ARB_multi_draw_indirect
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_occlusion_query2
    GL_ARB_pixel_buffer_object
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_program_interface_query
    GL_ARB_provoking_vertex
    GL_ARB_robust_buffer_access_behavior
    GL_ARB_robustness
    GL_ARB_sample_shading
    GL_ARB_sampler_objects
    GL_ARB_seamless_cube_map
    GL_ARB_separate_shader_objects
    GL_ARB_shader_atomic_counters
    GL_ARB_shader_bit_encoding
    GL_ARB_shader_image_load_store
    GL_ARB_shader_image_size
    GL_ARB_shader_objects
    GL_ARB_shader_precision
    GL_ARB_shader_storage_buffer_object
    GL_ARB_shader_subroutine
    GL_ARB_shader_texture_lod
    GL_ARB_shading_language_100
    GL_ARB_shading_language_420pack
    GL_ARB_shading_language_include
    GL_ARB_shading_language_packing
    GL_ARB_shadow
    GL_ARB_stencil_texturing
    GL_ARB_sync
    GL_ARB_tessellation_shader
    GL_ARB_texture_border_clamp
    GL_ARB_texture_buffer_object
    GL_ARB_texture_buffer_object_rgb32
    GL_ARB_texture_buffer_range
    GL_ARB_texture_compression
    GL_ARB_texture_compression_bptc
    GL_ARB_texture_compression_rgtc
    GL_ARB_texture_cube_map
    GL_ARB_texture_cube_map_array
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_gather
    GL_ARB_texture_mirrored_repeat
    GL_ARB_texture_multisample
    GL_ARB_texture_non_power_of_two
    GL_ARB_texture_query_levels
    GL_ARB_texture_query_lod
    GL_ARB_texture_rectangle
    GL_ARB_texture_rg
    GL_ARB_texture_rgb10_a2ui
    GL_ARB_texture_storage
    GL_ARB_texture_storage_multisample
    GL_ARB_texture_swizzle
    GL_ARB_texture_view
    GL_ARB_timer_query
    GL_ARB_transform_feedback2
    GL_ARB_transform_feedback3
    GL_ARB_transform_feedback_instanced
    GL_ARB_transpose_matrix
    GL_ARB_uniform_buffer_object
    GL_ARB_vertex_array_bgra
    GL_ARB_vertex_array_object
    GL_ARB_vertex_attrib_64bit
    GL_ARB_vertex_attrib_binding
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_vertex_type_2_10_10_10_rev
    GL_ARB_viewport_array
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_ATI_texture_float
    GL_ATI_texture_mirror_once
    GL_S3_s3tc
    GL_EXT_texture_env_add
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_bindable_uniform
    GL_EXT_blend_color
    GL_EXT_blend_equation_separate
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_compiled_vertex_array
    GL_EXT_Cg_shader
    GL_EXT_depth_bounds_test
    GL_EXT_direct_state_access : NOT INITIALIZED
    GL_EXT_draw_buffers2
    GL_EXT_draw_instanced
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit
    GL_EXT_framebuffer_multisample
    GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
    GL_EXT_framebuffer_multisample_blit_scaled
    GL_EXT_framebuffer_object
    GL_EXT_framebuffer_sRGB
    GL_EXT_geometry_shader4
    GL_EXT_gpu_program_parameters
    GL_EXT_gpu_shader4
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_packed_float
    GL_EXT_packed_pixels
    GL_EXT_pixel_buffer_object
    GL_EXT_point_parameters
    GL_EXT_provoking_vertex
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_shader_objects
    GL_EXT_separate_specular_color
    GL_EXT_shader_image_load_store
    GL_EXT_shadow_funcs
    GL_EXT_stencil_two_side
    GL_EXT_stencil_wrap
    GL_EXT_texture3D
    GL_EXT_texture_array
    GL_EXT_texture_buffer_object
    GL_EXT_texture_compression_dxt1
    GL_EXT_texture_compression_latc
    GL_EXT_texture_compression_rgtc
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_cube_map
    GL_EXT_texture_edge_clamp
    GL_EXT_texture_env_combine
    GL_EXT_texture_env_dot3
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_format_BGRA8888 : NOT INITIALIZED
    GL_EXT_texture_integer
    GL_EXT_texture_lod : NOT INITIALIZED
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp
    GL_EXT_texture_object
    GL_EXT_texture_shared_exponent
    GL_EXT_texture_sRGB
    GL_EXT_texture_sRGB_decode
    GL_EXT_texture_storage : NOT INITIALIZED
    GL_EXT_texture_swizzle
    GL_EXT_texture_type_2_10_10_10_REV : NOT INITIALIZED
    GL_EXT_timer_query
    GL_EXT_transform_feedback2 : NOT INITIALIZED
    GL_EXT_vertex_array
    GL_EXT_vertex_array_bgra
    GL_EXT_vertex_attrib_64bit
    GL_EXT_import_sync_object : NOT INITIALIZED
    GL_IBM_rasterpos_clip
    GL_IBM_texture_mirrored_repeat
    GL_KHR_debug
    GL_KTX_buffer_region
    GL_NV_alpha_test : NOT INITIALIZED
    GL_NV_blend_minmax : NOT INITIALIZED
    GL_NV_blend_square
    GL_NV_complex_primitives : NOT INITIALIZED
    GL_NV_compute_program5 : NOT INITIALIZED
    GL_NV_conditional_render
    GL_NV_copy_depth_to_color
    GL_NV_copy_image
    GL_NV_depth_buffer_float
    GL_NV_depth_clamp
    GL_NV_draw_texture : NOT INITIALIZED
    GL_NV_ES1_1_compatibility : NOT INITIALIZED
    GL_NV_explicit_multisample
    GL_NV_fbo_color_attachments : NOT INITIALIZED
    GL_NV_fence
    GL_NV_float_buffer
    GL_NV_fog_distance
    GL_NV_fragdepth : NOT INITIALIZED
    GL_NV_fragment_program
    GL_NV_fragment_program_option
    GL_NV_fragment_program2
    GL_NV_framebuffer_multisample_coverage
    GL_NV_geometry_shader4
    GL_NV_gpu_program4
    GL_NV_gpu_program4_1 : NOT INITIALIZED
    GL_NV_gpu_program5
    GL_NV_gpu_program_fp64
    GL_NV_gpu_shader5
    GL_NV_half_float : NOT INITIALIZED
    GL_NV_light_max_exponent
    GL_NV_multisample_coverage
    GL_NV_multisample_filter_hint
    GL_NV_occlusion_query
    GL_NV_packed_depth_stencil
    GL_NV_parameter_buffer_object
    GL_NV_parameter_buffer_object2
    GL_NV_path_rendering
    GL_NV_pixel_data_range
    GL_NV_point_sprite
    GL_NV_primitive_restart
    GL_NV_register_combiners
    GL_NV_register_combiners2
    GL_NV_shader_atomic_counters : NOT INITIALIZED
    GL_NV_shader_atomic_float
    GL_NV_shader_buffer_load
    GL_NV_shader_storage_buffer_object : NOT INITIALIZED
    GL_NV_texgen_reflection
    GL_NV_texture_barrier
    GL_NV_texture_compression_vtc
    GL_NV_texture_env_combine4
    GL_NV_texture_expand_normal
    GL_NV_texture_lod_clamp : NOT INITIALIZED
    GL_NV_texture_multisample
    GL_NV_texture_rectangle
    GL_NV_texture_shader
    GL_NV_texture_shader2
    GL_NV_texture_shader3
    GL_NV_transform_feedback
    GL_NV_transform_feedback2
    GL_NV_vertex_array_range
    GL_NV_vertex_array_range2
    GL_NV_vertex_attrib_integer_64bit
    GL_NV_vertex_buffer_unified_memory
    GL_NV_vertex_program
    GL_NV_vertex_program1_1
    GL_NV_vertex_program2
    GL_NV_vertex_program2_option
    GL_NV_vertex_program3
    GL_NVX_conditional_render : NOT INITIALIZED
    GL_NVX_gpu_memory_info
    GL_OES_compressed_paletted_texture
    GL_OES_depth24 : NOT INITIALIZED
    GL_OES_depth32 : NOT INITIALIZED
    GL_OES_depth_texture : NOT INITIALIZED
    GL_OES_element_index_uint : NOT INITIALIZED
    GL_OES_fbo_render_mipmap : NOT INITIALIZED
    GL_OES_get_program_binary : NOT INITIALIZED
    GL_OES_mapbuffer : NOT INITIALIZED
    GL_OES_packed_depth_stencil : NOT INITIALIZED
    GL_OES_point_size_array : NOT INITIALIZED
    GL_OES_point_sprite : NOT INITIALIZED
    GL_OES_rgb8_rgba8 : NOT INITIALIZED
    GL_OES_read_format
    GL_OES_standard_derivatives : NOT INITIALIZED
    GL_OES_texture_3D : NOT INITIALIZED
    GL_OES_texture_float : NOT INITIALIZED
    GL_OES_texture_float_linear : NOT INITIALIZED
    GL_OES_texture_half_float : NOT INITIALIZED
    GL_OES_texture_half_float_linear : NOT INITIALIZED
    GL_OES_texture_npot : NOT INITIALIZED
    GL_OES_vertex_array_object : NOT INITIALIZED
    GL_OES_vertex_half_float : NOT INITIALIZED
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_lod
    GL_SGIX_depth_texture
    GL_SGIX_shadow
    GL_SUN_slice_accum
    GL_WIN_swap_hint
    WGL_EXT_swap_control : NOT INITIALIZED
    WGL_ARB_buffer_region
    WGL_ARB_create_context
    WGL_ARB_create_context_profile
    WGL_ARB_create_context_robustness
    WGL_ARB_extensions_string
    WGL_ARB_make_current_read
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_ARB_pixel_format
    WGL_ARB_pixel_format_float
    WGL_ARB_render_texture
    WGL_ATI_pixel_format_float
    WGL_EXT_create_context_es_profile
    WGL_EXT_create_context_es2_profile
    WGL_EXT_extensions_string
    WGL_EXT_framebuffer_sRGB
    WGL_EXT_pixel_format_packed_float
    WGL_EXT_swap_control_tear
    WGL_NVX_DX_interop
    WGL_NV_DX_interop
    WGL_NV_DX_interop2
    WGL_NV_float_buffer
    WGL_NV_multisample_coverage
    WGL_NV_render_depth_texture
    WGL_NV_render_texture_rectangle
    : NOT INITIALIZED
    OpenGL features for current hardware:
    OpenGL provider: NVIDIA Corporation
    OpenGL renderer: GeForce GTX 560/PCIe/SSE2
    OpenGL version: 4.3.0
    Maximum number of lights: 8
    Number of auxiliary buffers: 4
    Number of texture units: 4
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 16384 x 16384
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 0
    GLSL version: 4.30 NVIDIA via Cg compiler
    Shadow mapping supported
    VBO supported
    *** Scene Cleared ***
    Loading plug-ins:
    630 x 760 - 69K
    Post edited by Ivy on
    I took a snip-it of what i am trying to render and my performance reading .. as you can see I'm barely using any of my resources
    it crashes with out even a warning on render
    1915 x 1169 - 307K
    Platform bits: 32
    It says this at the top of the log?
    It looks like you are using the 32 bit version of DAZ Studio, and any 32 bit program will only have 4 GB of RAM available, no matter how much you have on your system. Is the PC actually rendering when you took that screenshot, I can't tell from the image, but it doesn't look like it, and it would leave very little memory for rendering.
    If you have a 64 bit system, you would be much better to use the 64 bit version of DS4.6
    Platform bits: 32
    I see ..
    well than I guess I won't be able to use this version either of daz either.
    because Animate2 & some of ther light plugins do not come in 64 byte, that is why i loaded the 32 byte version just because some of the plugins don't work in 64byte
    which i need in order to do animation. rather silly to limit how much memory can be allotted to use by a program.
    edited May 2013
    As far as I know, Animate 2 is a 64 bit plugin, I have it on my 64 bit version of DS, and it works fine. I believe that there was one plugin that only worked on 32 bit, but I can't remember what it was now.
    The memory limit is not imposed by DAZ 3D, it is a physical restriction, since 32 bit addresses can only address up to 4GB of RAM before running out of numbers. It used to be restricted by Microsoft in XP to 2 GB.
    Post edited by JimmyC_2009 on
    Thanks Jimmy
    I did as you suggested and installed 64byte., it did resolve the crash on render issue like you said, I did a quick render for you this was one raytrace. and 1 deep showdow map spot. and it rendered great,
    and I only lost 2 plugins which are really for poser anyway. Animator and light-dome2
    Thanks for the advice and the help :).
    1920 x 1080 - 268K
    Glad I could help, a very nice render, thanks for posting.
    Yes, some of the plugins were not updated, like Animator, I have it myself. And Dreamlight didn't update LD2, but you never know, maybe in the future. There are far fewer problems with the 64 bit version during renders.
