my render has turned into a big black and white picture?
dale_larsendale_larsen Posts: 19
edited January 2018 in New Users
complete newbie here,
I was doing the interactive tutorials and right around the part when I was in the render section of the tutorial they had me change things to Iray engine and view and since then I can only render out these "matt" images.
I have tried everything including reversing the tutorial steps to fix but no.
any thoughts?
1600 x 900 - 291K
1600 x 900 - 624K
Post edited by dale_larsen on
  • The editor tab of Render Settings may have some useful information. Also, go to Help>Troubleshooting>View Log, scroll right to the end and then look backwards to see if there are any 3delight error or warning messages in there.
  • I just ran a render and this is what the log said.
    "2018-01-12 15:11:15.530 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=60
    2018-01-12 15:11:18.224 Ran tdlmake on image /Users/Shared/My DAZ 3D Library/Runtime/Textures/Raiya/Georgia/RyGeorgia_torsoGenS_1002.jpg
    2018-01-12 15:11:18.734 Ran tdlmake on image /Users/Shared/My DAZ 3D Library/Runtime/Textures/Raiya/Georgia/RyGeorgia_torsoGenB_1002.jpg"
    I see WARNING, but the rest could be in Greek for all I know.
    as for the Editors tab in render settings, I went through everything and it's all been reset (to factory defaults I assume)
  • weird, I answered but the pst disappeared.
    is there a long lag time on posts appearing?
    the log says
    after a render.
    WARNING being significant to someone other than me.
    thoughts?
    as for the edit tab of the render section, all is reset to factory defaults
  • BeeMKayBeeMKay Posts: 7,019
    Have you tried saving the scene, closing DS and then restart it, and opening the saved scene again?
  • oh yes, I have tried a reinstal.using the unistal feature in the DIM but still happening.
  • for kicks I uninstalled both Daz and the DIM, searched the comp for anything with daz in it and deleted that.
    reinstalled the whole thing.
    did a render and have the same black and white issue.
    it's like it's a reverse matt of some kind.
  • FIXED IT.
    It occurred to me that their had to be a preference file someplace and did not recall seeing IT when I searched.
    sorted preferences by dated and found three.
    deleted those and reopened DAZ.
    had to re-enter login info etc.
    problem solved.
    no idea how I got the problem.
    should I do the tutrial again and pay attention?
    in the name of science.
  • I can't think of anything that would trigger an issue like that, other than corrupt/missing shaders (which is what I was thinking the log would show, and what BeeMKay's suggestion of a restart would have probably fixed). Perhaps it was something in your settings, since a clear and rebuild fixed the issue, but I don't know what - rerunning the tutorial and seeing if it happens again might be interesting.
