How to save a shader preset
reelyorreelyor Posts: 235
I apologize for the redundancy, but after I modify a shader, how do I save the settings using the SAVE AS menu option?I selected the character in the Scene, chose the master surface for that character in the Surface menu, but when I try to save I get an error that an object having geometry must be selected as well as at least one surface on that object.
I want to save the shader preset for the skin of a character.
Thanks
    I just tried this.
    You have to only select ONE surface of the object, or you will get an error. I did that (eventually), and it saved OK, and I was able to apply it to a Sphere.
  • reelyorreelyor Posts: 235
    Thank you. I did as you said and it worked.
  • evilkooladeevilkoolade Posts: 114
    I just tried this.
    how do you select a surface
    I just tried this.
    By going to the Surfaces pane and selecting it by name, or using the Surface Selection tool from the toolbar (Alt+Shift+M), and clicking on the surface that you want.
