Show stopper hexagon displacement tool bug "An internal error has occurred" and more.
Bug 1: Show stopper hexagon displacement tool bug "An internal error has occurred"
When making a morph in hexagon using the displacement tool I keep getting "An internal error has occurred" messages. I can use the tool for about 5 minutes before the error pops up. Once it pops up, anywhere I click makes the error pop up immediately after closing the error message.
It kind of seems to happen when using it on somewhat sharp angular edges of the model. I was using it to smooth bumps around the nose are and remove teeth in the jack pumpkin model.
Also, once this error has occurred, when I click 'file->save as', nothing happens, so the only way to recover the work is to send it back to daz, which also doesn't always work once the error has happened.
This pretty much makes hexagon useless for me, is there any way around this?
Bug 2: The files I made before upgrading to DAZ 4.6 are now broken.
DAZ can't find the muscle morphs or gut files. I tried using the install manager to uninstall everything and reinstall everything but it still can't open the files I made with these models in the old version of DAZ studio. I am able to make a brand new models that includes the muscle morphs and guts, but I can't open the old file. Here is some of what the log file says, there are about 2000 lines of these:
Unable to find file for storable: data/4_0_2/M4_Gut_60691/M4_Gut_60691/modifiers/morphs/jcmHeadSSR_neck_144.dsd
Unable to find file for storable: data/4_0_2/M4_Gut_60691/M4_Gut_60691/modifiers/morphs/jcmHeadSSL_neck_144.dsd
Unable to find file for storable: data/4_0_2/M4_Gut_60691/M4_Gut_60691/modifiers/morphs/jcmHeadTwistL_neck_144.dsd
Unable to find file for storable: data/4_0_2/M4_Gut_60691/M4_Gut_60691/modifiers/morphs/jcmHeadTwistR_neck_144.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/M4_Thorax_50985/geometry_959716ab_7b73_2829_beab_9d1968b52218/M4_Thorax.dso
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadExtend_chest_814.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadFlex_chest_812.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadSSL_chest_814.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadSSR_chest_814.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadTwistL_chest_915.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadTwistR_chest_911.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadExtend_neck_2900.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadFlex_neck_2900.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadSSL_neck_2900.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadSSR_neck_2900.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadTwistL_neck_2900.dsd
Unable to find file for storable: data/4_0_2/M4_Thorax_50985/M4_Thorax_50985/modifiers/morphs/jcmHeadTwistR_neck_2900.dsd
Unable to find file for storable: data/4_0_2/blMilMan_m4b_68498/blMilMan_m4b_68498/blMilMan_m4b_68498/geometry_f1b6f5eb_eb04_b5f7_d1ea_021ba0a5bba4/blMilMan_m4b.dso
Unable to find file for storable: data/4_0_2/blMilMan_m4b_68498/blMilMan_m4b_68498/modifiers/morphs/PBMHipsCrest_hip_388.dsd
Unable to find file for storable: data/4_0_2/blMilMan_m4b_68498/blMilMan_m4b_68498/modifiers/morphs/PBMHipsSize_hip_912.dsd
Unable to find file for storable: data/4_0_2/blMilMan_m4b_68498/blMilMan_m4b_68498/modifiers/morphs/PBMHipsSpandex_hip_202.dsd
Unable to find file for storable: data/4_0_2/blMilMan_m4b_68498/blMilMan_m4b_68498/modifiers/morphs/PBMGlutesSize_hip_494.dsd
I am able to find at least one of these files (PBMGlutesSize_hip_494.dsd) in what looks to be the right spot (see screenshot) so I'm not sure what the problem is.
I Also EDITED your title as it was breaking the forum Formatting.
That's the way the installers has set things up, I'm not sure why one is two and one is three or why it changed. I had originally installed the muscle morphs and the rest by running the exe installers manually because I was unable to get the install manager to run at all because of a video card file conflict. Once I got it running I have installed everything since using the manager.
Maybe the exes for the muscle morphs and gut files install things in different spots from the install manager?
Thanks for clarifying that. Since you're aware of the problem, it would be nice if at the forum 'submit' button it warned the user to make a backup of their post since it's a known issue that the forum will probably throw it out.
