Is there a record player prop?
I'm looking for the type that a kid in the 70's might have. Just a table top version. Sorta like the picture I attached. I am pretty sure i can figure out one that will work using primatives but I just thought I'd check and see if a professional might have made one. I did a search and didn't turn up much.
300 x 250 - 13K
Well, it's not cheap and it's not here, but https://www.renderosity.com/mod/bcs/retro-lp/100174/
This is in Renderosity freestuff, but I can't tell what format it is; given age, probably either Poser or OBJ: https://www.renderosity.com/mod/freestuff/portable-record-player/61558
This reportedly has OBJ files , which will work in Studio, though it's probably not quite what you wanted: http://www.sharecg.com/v/86148/browse/5/3D-Model/Low-Poly-Record-Player
Poser format, but probably the wrong period and will probably need retexturing: http://www.sharecg.com/v/17512/browse/11/Poser/1950-Phonograph
Not quite what you're looking for, but if you're willing to do a bit of modding, there's also this:
https://www.daz3d.com/high-fidelity
Also there are some free turntable props over at Turbosquid. Can't vouch for their quality, though. I've never shopped there.
