Where do I enable the visual guide/frame for render dimensions in preview mode?
NansteinNanstein Posts: 43
In previous versions of DS, when you go to Render Settings and change the dimensions for an image you're about to render to a custom setting, there used to be a helpful box or frame displayed in preview mode that shows you how much of your scene is going to show up in that render you're about to do. I really need that. Is it disabled by default? Where do I enable it? I have looked for this setting in Preferences, but all I found was the ability to tell DS to ignore your latest render settings when starting a new scene.
Thanks in advance :-)
Post edited by Nanstein on
    It is in the drop-down menu for the Viewport, (a small lined square with a triangle), and it is called Show Aspect Frame, just tick that and it will display.
  • NansteinNanstein Posts: 43
    JimmyC, you made my day! :D Thank you ten hundred times.
    My pleasure :-)
