Way of the Shinobi Controls- Outfit Won't Take Adjustments
NovicaNovica Posts: 23,887
The title says it all. I've had no problem, ever, with an outfit not reacting to the sliders and moving the clothes. No matter which one I move, nothing happens. It will bend a little then bounce back. I am using Aiko 5 and there is even an Aiko 5 dial, same deal. It's the shoulder straps which curve way above the shoulders. Any way to turn off set positions on a top?
1017 x 866 - 63K
  • scorpioscorpio Posts: 8,417
    The Yoroi Breast piece has been modelled to for over the Haori, without it there will be gaps. Sometimes venders create a morph so that a 'vest' can be used without the shirt, this set doesn't have that. The only way might be to scale the item to fit.
  • NovicaNovica Posts: 23,887
    Yep, I tried to scale and then translate Y. No luck (to bring the straps down.) Thanks for the tip though, appreciate you! :) I'll just have to add the other piece. It's a nice outfit, got it during one of the recent sales and just playing with it. Nice to know it wasn't something I was doing, it was so funny to see the piece bounce back time and time again. I was like "What ARE you doing?" (then...) "What am I doing?"
    Cathie
    Okay, next question- I clicked on a "prop" that put the sword in the right hand. How do I undo it? There's nothing in Scene to remove, and clicking the undo doesn't undo it. So how do you change a pose and get it back out of the scene?
    You mean you want to delete the sword from the scene, select it - press delete on keyboard, if for some reason you can't select it in the viewport it will be parented to the hand in the scene tab hierarchy.
    edited May 2013
    Never mind- I right clicked on the sword and got it to delete from scene.
    EDIT: posting at the same time! But thanks! And it's good to know about the parenting in the Scene tab.
    Post edited by Novica on
