How do I see the full model while rotating the view?
Kid_KaboomKid_Kaboom Posts: 20
edited May 2013 in New Users
Hi! I'm brand new to Daz3D 4.6 and I've mostly used Poser for the last 10 years.
I have a silly little problem which I know how to fix in poser but not in Daz3D
but I'm not quite sure how to explain it so I attach this image - hopefully it shows up somewhere in this post.
So my problem is:
When I load a model it looks all fine, but as soon as I start shaping or rotating, the model turns into
these weird floating angles and lines. What I want is to see the model shape or rotate in real time.
This was possible last I used Daz3D (too long ago) so I'm sure I've just missed an option somewhere.
Also, how do I change the background color from the white to, say, gray?
Help would be greatly appreciated, thanks!
Image removed for nudity. Please see this thread for info: http://www.daz3d.com/forums/discussion/3279_98/
Post edited by fixmypcmike on
  • fixmypcmikefixmypcmike Posts: 19,612
    Go to Window > Panes > Tool Settings; under "During Manipulation" change "Draw Style" to "Use Current (Off)".
    In the Viewport click the Options icon (the rectangle with horizontal lines) to change background color.
  • Kid_KaboomKid_Kaboom Posts: 20
    Thanks for the help, that seems to have worked!
    Also apologies for the image that needed moderation, I did not mean to cause any grievance.
  • frank0314frank0314 Posts: 14,297
    Just make sure the figure is untextured or has clothing on covering it up. You didn't cause any issues so don't feel bad about it.
